EXTERIOR mods are DONE | Three locations PHOTOSHOOT | 33 large size PICS
First, here's the current mod list
Exterior:
- Vorsteiner CSL front bumper
- BMW OEM CSL trunk
- CSL style CF rear diffuser
- CF Kidney Grilles
- CF Side Grilles
- CF Headlight trim set
- Smoked front corners
- Black Roundels
- Silvervision turn signal bulbs
- Umnitza Predator Chromium DDE
- ProLumen 6000K HID bulbs (not installed)
Wheels & Tires:
- Kinesis F110 19x8.5 (18 lbs) and 19x10 (19 lbs) wheels
- Bridgestone S03 245/35-19 and 275/30-19 tires
- Turner Motorsport 8mm spacers
Suspension & Braking:
- Brembo GT 4-piston front calipers (custom painted yellow) with 14" front rotors
- Brembo 4-piston rear calipers (custom painted yellow) with OEM 12.9" rear rotors
- Goodridge stainless steel braided front brake lines
- Hawk HPS F+R brake pads
- KW Variant 2 coilovers
- Dinan front swaybar
- Quattro CF front strut bar (not installed)
Engine:
- Dinan Vortech Supercharger (4.6 psi Boost Pressure)
- Dinan high flow cold air intake
- Larger capacity fuel injectors
- Racing-Style aluminum radiator
- Dinan engine management System
- Dinan high flow throttle bodies
- Evosport headers with ceramic coating
- Evosport high flow cats
- Milltek section 2
- Milltek exhaust
- UUC Stage II lightweight flywheel
- UUC UltraSmooth Cerametallic clutch kit
- Rogue tranny mounts
- UUC EVO3 SSK
- UUC DSSR
- Defi control unit & BF gauges (Boost, Oil Temp, EGT)
- Modified CDV from Zeckhausen.com
- CF engine cover and other parts
Interior/Audio:
- Silver CF steering wheel
- UUC RK Shadow CF shift **** and CF e-brake
- LeatherZ alcantara shift and e-brake boots with red stiching
- LeatherZ Gauge Panel
- Valentine One radar hardwired
- OEM homelink
- Silver CF interior trim set (not installed)
- Tru Technology T-2.100 amp (not installed)
- Seas Excel 6" midbass speakers (not installed)
- Phass AT28 tweeters (not installed)
- Custom passive crossovers (not installed)
- JL 10W6v2 subwoofer (not installed)
- JL 500/1 mono amp (not installed)
Exterior:
- BMW OEM CSL trunk
- CF Kidney Grilles
- CF Side Grilles
- Black Roundels
Wheels & Tires:
Engine:
- Milltek section 2
- Milltek exhaust
- UUC EVO3 SSK
- UUC DSSR
Interior/Audio:
- OEM homelink
