Go Back   6speedonline.com Forums > Tech Stuff > Tech / How To
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-11-2009, 07:36 AM #1
Sargepug is a glorious beacon of lightSargepug is a glorious beacon of lightSargepug is a glorious beacon of lightSargepug is a glorious beacon of lightSargepug is a glorious beacon of lightSargepug is a glorious beacon of light
Restart after stall
I naturally have stalled the car a couple times from a stop. The biggest factor for me to get used to is that lack of torque at the low rpms. Not to say this car is low, but to compare to the othe torque monsters in my garage, I am not used to the lack of instant torque to get you going off the line at low rpms. My issue is this, after the car stalls it seems difficult to get the car to turn over again electonically. The ignition is dead until i pull out the key and give a coupe secs to reset. Why after a stall, cant I simply push the clutch back in and refire, why the drawn out procedure?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 10-11-2009, 03:39 PM #2
IAPorscheDoc's Avatar
1986 Porsche 944
My Garage
IAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud ofIAPorscheDoc has much to be proud of
You don't have the pull the key out, you just have to cycle it on and off quickly, and then it will start. No delay necessary. If it needs a few seconds, I would suspect a bad ignition switch.
Doc Wilen
86 951....not stock
Old 10-12-2009, 09:50 AM #3
Quote:
That very well may be the issue, I am a seasoned manual driver of 25 yrs and automatically, I do the quick cycle to restart. It simply does not work, I will have the dealer take a look at it.
Old 10-13-2009, 09:16 AM #4
Hey Doc, here is what my guy in service said. I also asked him about changing the oil @ 700 miles and the break-in. What are your thoughts?
At this point (700 miles) you should be fine, as I stated before in my last email these engines are bench tested for quite some time before they go into the car. As for the ignition switch thing I have seen a couple of them but not to the point where I would say this is a "common" problem. Now for having to take your key out of the ignition after it stalls that is a safety mechanism in the car where it will not allow you to restart the vehicle if you do stall it without having to take the key out first. Just the way it works....
Reply
Tags
1986, 930, car, cool, porsche, restart, restarting, roush, stalls, turbo, turns
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
