DIY 997 Series Porsche 911s
#38
Thank you again!!!!!
#43
Not in the manual. There is circular mumbo on tether, but nothing about removing the seat cushion. I'm going to go give it a pull in the morning.
#44
The bottom is Velcro give 'er a good tug. I removed that and the back pad/shelf for my boys. Those alone were like 40lbs in weight savings
#45
It did pull out real easy! Thank you! I learned a couple things:
1) The Recaro Vivo car seat only fits with the head rest in the lowest position. For taller kids it will not work because the head rest pushes down on the shoulders.
2) Anyone putting in a car seat should definitely remove the seat pads to preserve them from damage.
3) The prior owner must of had kids, because it was cookie crumb city when I pulled the pad out!
Thanks!!
Don
Thanks!!
Don
