Go Back   6speedonline.com Forums > Tech Stuff > Track & Autocross
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-20-2009, 09:55 AM #1
2008 Porsche Carrera
nugent_crai is a glorious beacon of lightnugent_crai is a glorious beacon of lightnugent_crai is a glorious beacon of lightnugent_crai is a glorious beacon of lightnugent_crai is a glorious beacon of light
Are my tires too inflated for the street?
Im pretty sure they are too inflated for my driving style because of the tread wear, but my dash says they are 36-40ish. Ive heard the dash being as much as 5lbs off though.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
ID:	107804   Click image for larger version
ID:	107805   Click image for larger version
ID:	107806   Click image for larger version
Old 10-20-2009, 11:04 AM #2
elh0102 is on a distinguished road
Yes, the TPM system is not sufficiently accurate to use in place of a manual guage. I can't see the photos in sufficent detail to respond, but, if the tires are over-inflated, you will see excessive wear in the center portion of the tire, assuming no alignment issues. 40 pounds at operating temperature should not cause such problems.
Old 10-23-2009, 01:40 PM #3
click on the photo's they enlarge
Old 10-23-2009, 03:30 PM #4
Quote:
Yes, but they all show just the outside edge, not the entire cross-tread area. Just measure the tread. If the tire is wearing more in the center, that usually indicates too much pressure. Under-inflation usually wears both inner and outer edges. Of course, alignment and driving style affects the wear pattern too. I expect you would have to be in the upper 40's to see premature wear from over-inflation.
Old 10-23-2009, 03:43 PM #5
theblue's Avatar
theblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant futuretheblue has a brilliant future
if you find you are wearing just the outside edge then try some more camber and pressure.
sold: Evolution VIII
BMW 97' 328ic sport 5spd
BMW 89' 325is with an M50 motor swap + track day setup
Old 10-23-2009, 04:23 PM #6
Brando's Avatar
Brando will become famous soon enoughBrando will become famous soon enough
Cool
From the pics, they look under inflated if anything.
But it could just be an alignment problem.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Seal Grey 996 C4S
Reply
Tags
911, center, inflate, inflated, tires, turbo, wearing
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
