Air Force Suspension Air Tank Cylinder System
Today we will be showcasing the Air Tank Cylinder System from Air Force Suspension. This is not a review, it is a product introduction designed to inform you the user with the product design and ability.
The Air Tank Cylinder System is a coilover upgrade set installed with a private cylinder on top of each coilover to control the raise and down of the coilovers.
With a air tank cylinder you can raise or drop your car in a range of
40mm - 60mm with a touch of button.
Like any other coilover upgrades, it improves handling performance by stronger suspension and lowering your car.
With the cylinder applied with the coilover, it does not affect the performance of the handling.
The great thing about this system is that in every coilover upgrade, and lowering car. The problem is to avoid many odd road conditions, such as parking lot bumps, basements, or pot holes. With a touch of a button,
you can raise up your car to max of 60mm to drive over these odd road conditions.
Most affordable Air Tank suspension system. This Kit comes with a "in-car" paddle valve swtich, which controls the "raise / drop" of your car. With out the wireless remote control unit, and solenoid valves. Made installation much easier, and affordable for your needs. This package contains with a "wireless remote control" unit. Which allows you to remotely control your car while you are outside of your car. The "raise / drop" control unit uses a eletronic control swtich, which controls solenoid valves that makes the "raise / drop" movement much faster.
Deluxe Package
Package includes:
* 3 GALLON AIR TANK W/ 4 X 1/4 PORT X 1
* HIGH SPEED COMPRESSOR X 1
* SNUBBER FOR MOTOR USE X 4
* HIGH PRESSURE HOSE FOR MOTOR USE X 1
* HIGH-TECH SILENCERS PLATE BASE X 1
* 175 – 200 PSI PRESSURE SWITCH X 1
* ELECTRIC SWITCH POLE DOUBLE THROW MOMENTARY X 2
* 200 PSI DUAL NEEDLE GAUGE X 1
* ELECTRIC SWITCH AND GAUGE BRACKET X 1
* 1/4 SOLENOID VALVE X 4
* 25M 1/4 AIR LINE X 1
* 10M POWER CORD X 1
* FUSE BOX X 1
* FITTINGS X 1
* REMOTE CONTROL X 1
* RECEIVER X 1
* SHOCK ABSORBERS
(INCLUDING TOP MOUNT, SHOCK BODY) WITH 36 LEVELS OF ADJUSTABLE DAMPENING X 4
* AIR CYLINDERS X 4
* MANUAL INSTALLATION X 1
Information Source: Air Force Suspension
If you have any inquiries about this product please PM me.
Deluxe Package
Package includes:
* FUSE BOX X 1
* FITTINGS X 1
* RECEIVER X 1
* SHOCK ABSORBERS
* AIR CYLINDERS X 4
04-28-2022 12:38 AM
