Tuning/Modifications
Sponsored by: Supersprint
Agency Power Mitsubishi EVO X Fuel Rails
Old 02-28-2011, 11:18 AM
Agency Power's Avatar
Platinum Sponsor
Agency Power is just really niceAgency Power is just really niceAgency Power is just really niceAgency Power is just really nice
We just did a Blog post about this on our website and I thought some of you might be interested:
Agency Power High Flow Fuel Rail EVO X 08+
Agency Power has released their new Mitsubishi EVO X fuel rail. This fuel rail is a direct replacement for the factory unit. The fuel rail is CNC machined out of 6061 aluminum, then anodized in Agency Power Red, Silver, or Black. It fits with the stock fuel pressure regulator and fittings. The fuel rail can also be set up to work with larger AN lines and aftermarket kits as well, with a simple unscrew of a piece. You can’t go wrong with the Agency Power Evo X fuel rail.
Why is this Agency Power Fuel Rail better then stock? The AP fuel rail has the largest bore currently on the market which results in better fuel flow then stock. As well, the AP rail is designed to fit larger injectors, when upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
All Agency Power products come with a limited lifetime warranty.
drinaldis
09-28-2015 01:37 PM
turbotuner20v
09-11-2015 12:02 PM
Superaudiofreak
09-04-2015 03:22 PM
Ferrari
08-24-2015 04:35 PM
VGLNTE1
08-20-2015 08:14 PM
Quick Reply: Agency Power Mitsubishi EVO X Fuel Rails
