Custom Headlight Fab?
Maybe the wrong section, but as the tight states I am looking for a place that will fab up some custom headlight housings for me. What I want is a housing built to seal off a set of E46 projectors that I snagged. Just needs to fit into the area designated for the low beam headlight on the pop up for my T/A. Anyone know of a place that does this type of work? Thanks in advance!
The front part of the headlight is glued on so you can take it off with a heat gun or if your worried about adding too much heat and ruining it, I've seen people put it in a pot with hot water untill the glue lets up.
The big thing with headlights is you need to make sure when you put it back together that its air tight or it will fog up really bad. I've never heard of a place that actually rebuilds headlights. Its mostly guys at home doing thier own.
04-28-2022 12:38 AM
