Rennline Aluminum Track Mat Available At Pelican Parts!
https://cimg5.ibsrv.net/gimg/www.6sp...8fd501888d.jpg Brought To You By Pelican Parts! Rennline’s Track Mats give your interior the purposeful look of a racing Porsche and are the perfect solution for protecting your interior from the wear and tear of track driving. The only aluminum floor mat of its kind on the market, Rennline’s Track Mats are inspired by the floor design of factory Cup Cars to provide drivers a smooth flooring surface that enables the quick footwork demanded of track driving. Rennline’s Track Mats are constructed from lightweight anodized aluminum, weigh less than two pounds, and are stamped with reinforcing ribs for strength. They fit precisely over the contours of Porsche floors and affix with Velcro or can be permanently mounted if desired. For automobiles with molded one piece carpets, Track Mats fit directly over the non-removable floor carpeting and can be covered completely with the factory floor mats when not in use. One of the main benefits of Track Mats for these automobiles is the protection they afford the floor carpeting, which wears rapidly when the loose floor mats are removed for track driving. For automobiles with removable carpets, Track Mats attach directly to the floors with Velcro, bind the inner rocker and center tunnel carpeting in place, and prevent wear to the soft sound deadener surface of the factory floor pans. When not in use, Track Mats can be removed or simply covered with the stock floor mats. |
