930 Turbo Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
:: ECS Tuning :: Magnetic Oil Drain Plug | Only $12.95!
Old Jul 11, 2014 | 02:21 PM
ECS Tuning - Porsche's Avatar
Next oil change? Install an ounce of prevention with a drain plug that catches and holds ferrous particles with an iron grip, before they can cause expensive engine damage.
Complete with drain plug sealing ring, the ECS drain plug accepts standard aluminum sealing rings for your convenience.
Click Here for more information
Old Aug 22, 2014 | 03:08 PM
Interested in simple, effective, affordable engine protection? This ECS magnetic drain plug attracts and holds small ferrous metal particles that escape your oil filter, and holds on to them to prevent engine damage. Just wipe away the particles from the magnetic drain plug tip at each oil change to remove abrasive particles that would otherwise scar close-tolerance engine parts and polished surfaces.
The N42 Neodymium magnet used is 18 times stronger than the OEM version, and has a high resistance to demagnetization.
Old Dec 19, 2014 | 10:20 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
