Elephant Racing Strut Brace's Available At Pelican Parts!
https://cimg4.ibsrv.net/gimg/www.6sp...edc86eefd0.png Brought To You By Pelican Parts! Elephant Racing's 911/930 triangulated aluminum strut brace weighs a scant 3.3 lbs! Triangulation provides rigidity to hold camber settings under heavy corner loads. Compare to other manufacturer's triangulated braces weighing a portly 15 lbs! Lightweight and rigid - the perfect combination for your race/performance Porsche! Made from sturdy aluminum tubing our braces are tapered and terminated with quality rod-end fittings for precise alignment, adjustability and rigidity. Adjustable pre-load allows you to dial in a bit of extra camber if desired. All required mounting hardware is included. Fit and finish are excellent making these braces as attractive as they are functional. They bolt on easily and can use existing holes on most cars. The track version is triangulated for maximum rigidity. The basic is the non-triangulated street version, that offers added rigidity for the daily driver. The basic weighs in at 2 pounds. |
| All times are GMT -6. The time now is 07:31 AM. |
