930s cab question
Old May 25, 2008 | 03:38 PM
globalm3's Avatar
globalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond repute
930s cab question
Someone has one that he inherited and does not know how to put the top up and down. Is it manual or is there something he is doing wrong?
tia
Old Jul 18, 2008 | 05:59 PM
rgagliano's Avatar
rgagliano is infamous around these parts
930 cab top operation
Most likely it is an electric top, mine is and it is easy to operate.
First, unzip the rear window so as not to crush it and cause cracks. It also folds down much better that way.
Turn the ingnition to the first click. Look under the dash on the drivers side and you will set a rocker switch the toggles back and forth. This will make the top go up and down. It will not work if the ignition is not in the first click postion. A red light comes on the speedo as I recall and it starts working. I do it without thinking so I don't recall which way you push the rocker for each operation, it you push it the wrong way, it just won't work, so then push it the other way. The light will go out when the top is all the way up or down. If it doesn't work at all, you will need to look into the electric motors that operate each side of the top, or also look at the fuses first.
If it is a manual top, there will be two handles just above the winshield, flip those and unzip the window and simply throw the top back.
Good luck to you.
Old Jul 19, 2008 | 09:25 AM
globalm3's Avatar
Good luck to you.
Thanks for your help we got it figured out.
Old Jul 19, 2008 | 02:32 PM
rgagliano's Avatar
U R Welcome.
991carreradriver
Aug 30, 2015 04:16 PM
TT Surgeon
Aug 29, 2015 11:16 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 26, 2015 04:55 PM
PelicanParts.com
Aug 20, 2015 03:11 PM
PelicanParts.com
Aug 18, 2015 04:01 PM
