AT Power 45mm Plug and Play ITB Kit for Porsche 964 - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > Porsche (Past) > 964
Reload this Page >
Old 08-09-2018, 06:43 PM
vividracing's Avatar
Premium Sponsor
vividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond repute
The basic idea of an intake manifold is to direct air from the throttle body to the individual intake ports on the cylinder head. The problem is, most intake manifolds don’t flow that well, resulting in less than optimal power levels. The idea behind individual throttle bodies (ITB for short) is to replace the single throttle body with a small throttle body for each intake port. This results in much better airflow and improved throttle response. For the Porsche 964 and 993, AT Power has just released their new plug and play ITB kit.
Of course, claims of power and throttle response improvement without proof are useless, so ATP dyno tested this ITB kit thoroughly. As tested by AT Power, gains of around 45 horsepower can be found with this kit. Of course, the gains depend on the age and condition of the Porsche, but there are impressive gains none-the-less. Unlike other kits on the market, this is a full plug and play unit that includes everything you need. This system has been designed to be a “bolt on kit” with absolutely NO modifications required to the car thus allowing it to be returned to its original condition.
Includes:
  • Specialist Components Delta 400 ECU with plug and play loom to connect the existing wiring harness
  • Base map
  • CAN tuning dongle
  • Air temperature sensor
  • Breather Filters
  • ITG Air Filters
  • Custom laser cut back plates (Handed)
  • PICO fuel injectors
  • Rennline Carbon Fibre heating duct
  • Racing lines fuel pressure regulator
  • Fuel lines and fittings with fuel flow diagram
  • Brake servo hose kit
If you have any questions about the AT Power ITB Kit for Porsche 964 and 993, please do not hesitate to contact us. We can be reached by phone at 1.480.966.3040 or via email at [email protected]
AUSTIN - Porsche Performance
1.480.966.3040 x246 / [email protected]
Porsche Performance Store // 997 996 Turbo ECU Flash // Cayenne ECU Tune // Boxster Cayman Flash // Carrera Tuning // Panamera Tuning
MAXRPM1
02-27-2017 10:03 AM
ricks234
09-10-2015 01:51 PM
totle
12-31-2014 04:14 AM
tblountman
09-17-2009 10:26 AM
Quick Reply: AT Power 45mm Plug and Play ITB Kit for Porsche 964
Join 6SpeedOnline
Visit our Sponsors
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
