The official 991 Turbo/Turbo S picture thread!
#181
Hi, thanks!
The wheels are HRE P107's in stock size with Cup 2's They look great, but FYI, don't look for weight savings moving from stock to these. I'm certain this is due to going to run flat from not run flat P Zeros. Had I stuck to the stock tires it would have been a couple pounds per corner weight savings I believe.
I am almost 100% certain that these P107's weigh less than the OEM offerings. Reason being - HRE's P1 series is one of the most lightweight Monoblock wheels out in the market today. Do you have the diameter and width on these? I can provide you with the weight on them and then compare them to what the OEM wheels are.
- David Nussbaum -
786 249 0127 (ext.2109)
Web: www.wheelsboutique.com
Email: David@wheelsboutique.com
YouTube Channel: https://www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
- David Nussbaum -
#182
Here's a few pictures of our newest shop car, 2017 991.2 Turbo S. Our first 991.2 Turbo S was Carrera White, but instead of white, we chose GT Silver this time...and I'm pretty happy with the way it turned out!
So far it's just got a Tubi Race exhaust, 21" Champion RG center-lock wheels, and H&R Springs. Should hopefully be running our full Stage 2+ package very soon.
#183
But as I've mentioned, this is with Cup 2's which are run flats instead of the stock P-zero's.
PM if you want more info, but this discussion doesn't belong in this thread.
#184
I can 100% guarantee and prove that they weigh more in the front and slightly less in the back than stock. I have the exact numbers but this is better for PM if you want.
The Pilot Sport Cup ZP is their only Cup run-flat tire I believe.
#185
Well then there's really no excuse for them to weight more than the front stock wheels with PZero's.
#186
#187
Hi, thanks!
#190
It would be great to know the weight of the OE 991.2 Centerlock wheels, and also full specs on these HRE P107.
It does not have to be top secret info !
#191
PM me, I'm happy to share.
#192
With the help of Uthatcher's tire/wheel weights we have answers
Stock fronts with Pirelli P Zero's weighed in at approximately 45 lbs each
Pirelli P Zero front weighs 23 lbs
OEM front wheel weighs 22 lbs
Stock rears with Pirelli P Zero's weighed in at approximately 57 lbs each
Pirelli P Zero rear weighs 29 lbs
OEM rear wheel weighs 28 lbs
HRE P107 fronts with MPSC2's weighed in at approximately 47 lbs each
MPSC2 front weighs 23 lbs
HRE front wheel weighs 24 lbs
HRE P107 rears with MPSC2's weighed in at approximately 56 lbs each
MPSC2 rear weighs 31 lbs
HRE rear wheel weighs 25 lbs
So in conclusion:
OEM's 22 lb fronts and 28 lb rears totaling 100 lbs
HRE's 24 lb fronts and 25 lb rears totaling 98 lbs
So in conclusion:
- David Nussbaum -
- David Nussbaum -
#193
It's not top secret, I just didn't want to hijack the thread. If I get time this evening I'll start a wheel thread with all the info.
