Presenting the AWE Tuning S-FLO Carbon Intake for the Porsche 991 Turbo and Turbo S
The first fully enclosed carbon fiber intake solution for the Porsche 991 Turbo and Turbo S.
Fully sealed carbon fiber box and filter combination
22% increase in air filter surface area
Features AWE Tuning S-FLO Filters
Airbox design increases intake and turbo spool sounds
Max gains of 22 hp and 22 ft-lbs of torque at the crank
Laser scanned engine bay yields optimal fitment and maximum flow
Perfect integration with OEM inlet ducting
Utilizes stock mounting locations
UV stabilized resin and clear coat prevent yellowing from heat
AWE Tuning S-FLO Filters are durable, and washable
Designed, engineered and tested in house at AWE Tuning
No Check Engine Light - Guaranteed
Perfect Fitment - Guaranteed
Images
The carbon fiber airbox
Fitment is guaranteed, Airbox geometry is 3D scanned, then optimized and mating to the factory air inlet pipes is perfect. The 100% carbon fiber AWE Tuning Porsche 991 Turbo and Turbo S S-FLO Carbon Intake is crafted from high grade 2x2 carbon fiber and boasts UV stabilized clear coat to prevent yellowing from under hood heat.
The smooth carbon fiber tubes inside the 100% enclosed air box provide a less restrictive path to the factory inlet pipes - in other words, when combined with the S-FLO Filter, we’re talking 22 hp and 22 ft-lbs of torque at the crank.
The AWE Tuning S-FLO Filter
The dual S-FLO Filters were specifically designed to maximize airflow in the AWE Tuning S-FLO Carbon Intake. The cleverly engineered S-FLO Filters increase surface area, resulting in increased airflow to your engine. Intake noises are also augmented, a subtle reminder of the engineering tucked beneath the carbon shell.
Power
Our carbon fiber airbox is not just for good looks, the AWE Tuning S-FLO Intake is optimized to keep IAT's consistently low to maximize power. The engine bay temperature of the 991 Turbo and Turbo S rapidly rises under full throttle acceleration. Closed course testing revealed that without the insulation of the carbon fiber S-FLO airbox, the engine would be ingesting air almost 10 degrees F hotter. The insulating effects of the S-FLO Intake, along with its superior aerodynamics and higher capacity air filters, results in peak power gains of 6 HP and 17 TQ and maximum power gains of 22 HP @ 5830 rpms vs stock.
Availability
The intakes are available now, either online or through AWE Tuning’s global network of incredible dealers and installation centers, right here (put in your zip, find your local AWE Tuning dealer).
Questions? AWE Tuning Porsche Performance Specialists await! 888.565.2257, performance@AWE-Tuning.com, or right here.
What a lovely piece of engineering. Amazing results, amazing looks and surprisingly a very competitive price. Keep up the good work. You guys are the best in my eyes. Job well done.
Thank you very much! We do our best to deliver a premium product that extracts reliable horsepower.
An upgrade that you can not only feel, but also hear.
Breathe easy and stay cool.
Click the image below to learn more about the AWE Tuning S-FLO Carbon Intake System for your Porsche 991 Turbo/Turbo S, and click here to find a dealer near you.
I would love to hear this to see if there is an increase in intake noise. Any clips of it with stock exhaust?
I have this love it all around! Car definitely seems to breath easier at our altitude. Cant really tell any additional sound one way or another. AWE, you need to work on the install guide a bit as we had to do some guesswork. just my .02
I'm really interested in the s-flo Carbon intake, but the issue I faced when I placed my order that the website says it shipped to US and Canada. I'm from United Arab Emirates.
We ship internationally, and our network of elite dealers stretches all across the globe. The nearest AWE Tuning Dealer to Abu Dhabi is Aryan Xtreme Motorsports!
Well, if you have x-ray vision, yes! Otherwise, no, unfortunately. It's covered.
Here's an AWE Tuning S-FLO Carbon Intake and Performance Intercooler equipped 991 caught obtaining a 167.8 mph in the 1/2 mile at this year's NoFlyZoneArizona, built by Goodspeed Performance Lab in AZ
Originally Posted by longboarder
Jeez this is a work of art. Can you see it when you open the engine decklid?
Very impressive performance gains for an intake...I'm particularly impressed with the goal of IAT suppression.
