Guys lowered on Techarts- Do you have this problem?
Guys- Do you have a clicking sound coming coming from the front end when you turn left or right? My setup is Techart's lowered on 21's.
GSC
GSC
It's common. Nothing will pop out. It's generally binding that happens. There are covers on the right coils to reduce this. It gets worse over time. I have heard of rocks or debris in there too. You can have the coils inspected with the car in the air. Check the condition of the coils and the covers or coating. I would believe it's worse out east.
I get the cracking sound on slow speed lock turns when leaving my sloped driveway. Have ever since I had the springs installed. My wheels and tires are stock.
The problem is the sway bar end links. Now that the car is lowered the end links are the wrong length and that needs to be changed.
To quickly identify that is the problem you can disconnect the end links and the noise should go away. To leave your sway bars connected and fix the problem you are going to need to install an adjustable sway bar end link so that will allow you to set the links at the correct length.
Tarret can make you a set of end links that are adjustable to fix the problem.
Only when very slow speed full-lock turns. Feels to me like the tires scrubbing / skipping across pavement. I've since stopped full-turns at very slow speed, such as pulling in garage, and no more issues. I'll pull forward, back-up in opposite direction and the go forward again.
