My 991 TTS Champion Turbo Upgrade Thread -- RedGutz Gets 68mm VTGs
#106
Originally Posted by cliffd
I know you did a number of mods at once but did you do the IPD plenum and high flow pipes. and if you did, can you notice a discernible difference? i cannot find any data other than the non-turbos that can give me data. Thanks
I tried aftermarket headers but the Dyno testing on my car revealed power loss from stock and no matter how we tried to tune the car we could not get any gains but only a loss. So I am running stock headers.
I am also running a stock y pipe. The Dyno testing of a car with identical mods to mine using aftermarket Y pipe did not reveal sufficient gains to justify the expense.
The only modifications I could do short of building the transmission and upgrading the clutch packs that would get me significant power gains is meth injection or nitrous. I have no interest in doing either.
#108
thanks, big help.
#109
I had the IPD Plenum but removed it and went back to stock after after an identically modded car showed power gains by removing the IPD plenum and going back to stock. This was with a GIAC tune so I make no representations about the Cobb tune and the IDD Plenum. So I am running a stock Plenum
Whats the brand on the headers?
Manuel
