Agency Power's PDK Cup Shifter - Shift Like You Mean It!
Having owned a slew of PDK cars, they are extremely fun to drive and shift so quick there is nothing else to compare. Our Project 997.2 Turbo, Project Panamera Turbo, Project 991 Turbo could have all used this new product. We introduce to you, the Agency Power Porsche PDK Cup Shifter! Why? Simple… although banging through the gears automatically is fast and fun, sometimes you just want to shift yourself. The paddles are functional to use on and off the track, but don’t give you that feeling of throwing your arm forward like a 6 speed manual. Yes you could do this with the factory PDK shift lever, but it is small and boring. When you are sitting in the seat you have to reach down to use it. With the Agency Power PDK Cup Shifter, it is 3 inches higher giving you almost parallel access to quickly bang through those PDK gears
https://www.vividracing.com/blog/wp-...lapStick-2.jpg https://www.vividracing.com/blog/wp-...lapStick-4.jpg https://www.vividracing.com/blog/wp-...lapStick-9.jpg This project started out with a concept and design to simply make a cooler shift knob of the PDK vehicles. With such a passion for Porsche vehicles and attracted to the way the 991 RSR sequential shifter looked, we went full throttle on this (no pun intended). Agency Power manufactures plenty of Porsche performance parts already for popular platforms like the 996, 997, and 991. This part adds to the large collection allowing customers to build a full Agency Power Porsche. RSR Sequential Shifter Influence https://www.vividracing.com/blog/wp-...-shifter-3.jpg https://www.vividracing.com/blog/wp-...-shifter-2.jpg https://www.vividracing.com/blog/wp-...eq-shifter.jpg Prototype with 3D Printed Parts https://www.vividracing.com/blog/wp-...lapstick-1.jpg https://www.vividracing.com/blog/wp-...lapstick-2.jpg https://www.vividracing.com/blog/wp-...lapstick-3.jpg https://www.vividracing.com/blog/wp-...lapstick-4.jpg Studio Shots https://www.vividracing.com/blog/wp-...apStick-15.jpg https://www.vividracing.com/blog/wp-...pStick-122.jpg https://www.vividracing.com/blog/wp-...pStick-131.jpg https://www.vividracing.com/blog/wp-...pStick-161.jpg Installation Photos https://www.vividracing.com/blog/wp-..._Install-1.jpg https://www.vividracing.com/blog/wp-..._Install-2.jpg https://www.vividracing.com/blog/wp-..._Install-3.jpg https://www.vividracing.com/blog/wp-..._Install-4.jpg https://www.vividracing.com/blog/wp-..._Install-5.jpg https://www.vividracing.com/blog/wp-..._Install-6.jpg https://www.vividracing.com/blog/wp-..._Install-7.jpg https://www.vividracing.com/blog/wp-..._Install-8.jpg https://www.vividracing.com/blog/wp-..._Install-9.jpg https://www.vividracing.com/blog/wp-...Install-10.jpg https://www.vividracing.com/blog/wp-...Install-11.jpg https://www.vividracing.com/blog/wp-...Install-12.jpg https://www.vividracing.com/blog/wp-...Install-13.jpg https://www.vividracing.com/blog/wp-...Install-14.jpg Product Photos https://www.vividracing.com/blog/wp-...lapStick-1.jpg https://www.vividracing.com/blog/wp-...pStick-2-1.jpg https://www.vividracing.com/blog/wp-...lapStick-3.jpg https://www.vividracing.com/blog/wp-...pStick-4-1.jpg https://www.vividracing.com/blog/wp-...lapStick-5.jpg https://www.vividracing.com/blog/wp-...lapStick-6.jpg https://www.vividracing.com/blog/wp-...pStick-7-1.jpg https://www.vividracing.com/blog/wp-...lapStick-8.jpg https://www.vividracing.com/blog/wp-...pStick-9-1.jpg https://www.vividracing.com/blog/wp-...apStick-10.jpg https://www.vividracing.com/blog/wp-...apStick-11.jpg Official Release by Agency Power The Agency Power Cup Shifter was designed to give PDK owners a whole new experience in driving their car. Mimicked after the factory cup car style shift knob and assembly, this product makes banging through the gears a lot more fun. The PDK shifts extremely fast but sometimes you want to do the work of going through the gears yourself. The paddles are fun and easy to keep ahold of, but some Porsche drivers just miss the shifting experience. Having your hand on the stock PDK lever does not feel to thrilling. The Agency Power Cup Shifter for the Porsche PDK changes that! The Cup Shifter is designed here in Gilbert, Arizona of several parts. Starting with CAD drawings and using 3D printed components, we developed a prototype to test in a vehicle which also allowed for easy installation. The stock knob comes off without requiring the removal of any other center console pieces. This process takes less than 20 minutes to swap our parts. It is necessary of the Cup Shifter to retain the function like the stock PDK knob. This requires the need to go between P, R, N, D with a spring mechanism. The shift knob is CNC machined from 6061 aluminum featuring the cup car style cavity on the top. Inside, it features an actuator pin and bushing to work with the stock spring compression. The weight of the knob is just right to give you a solid shifting sensation and the design is very ergonomic to the hand. The shift knob has been clear anodized over the brilliant CNC machined finished. The height of the shifter is increased about 3 inches over the stock PDK lever. This puts the Cup Shifter at a great position in reference to the steering wheel. You now can have quick hand placement from the steering wheel to shift knob to smash through the gears like a pro! Connecting the shift knob to the base is an eloquent carbon fiber tube with a slight gloss finish. This attaches to the base stock utilizing rubber O-rings for a secure fit, however lets you easily disassemble and reassemble. The base stalk is also CNC machined from 6061 aluminum. Clear anodized, the base features a very simple Agency Power AP logo that has been laser engraved. The finish on the base closely matches the factory PDK shifter surround to look OEM. The Agency Power Cup Shifter is designed to fit all Porsche PDK1 and 2 vehicles from 2009 forward. Agency Power is very proud of this product and its functionality. We support our products with top level customer service. Features: -Superior CNC machine quality -Cup car style shift knob -Carbon fiber center tube -Easy installation Let us know your thoughts! |
To bad it can't change the 991.1 shift direction to be like a cup shift or any other sequential race trans shift where you pull to go up in gear instead of push.
Glad the 991.2 fixed that. :) |
| All times are GMT -6. The time now is 06:08 PM. |
