991.2 oil change
Old 10-18-2017, 07:07 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
991.2 oil change
Hey fellas, did some research but couldn't find any threads on it for either .1 or .2, owners manual says 7.92 quarts of 0-40 and with this integrated dry sump there is indeed only 1 drain plug correct?! Don't want to make this mistake lol.
Old 10-21-2017, 07:12 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Yes, only 1 drain plug. You can use either 5 or 0 W 40 depending on climate and usage. Both Sam and Champion advised me to fill the oil to read in the center of the operating range rather than at the very top.
Old 10-21-2017, 08:13 AM
Jim M.'s Avatar
Jim M. will become famous soon enoughJim M. will become famous soon enough
Why only fill to the center instead of the top of the range. I'm sure they both know there stuff, but what is the reasoning?
Old 10-21-2017, 08:18 AM
Nanook's Avatar
Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !Nanook Is a GOD !
It's a performance secret...if they told you they'd have to ....
Old 10-21-2017, 09:34 AM
911tts-LA's Avatar
911tts-LA is a name known to all911tts-LA is a name known to all911tts-LA is a name known to all911tts-LA is a name known to all911tts-LA is a name known to all911tts-LA is a name known to all
So 7.5 quart?
Old 10-21-2017, 01:17 PM
Stage7's Avatar
I believe it has to do with the PCV system under high boost - especially when running higher boost than stock. Hopefully they will chime in.
Old 10-21-2017, 03:40 PM
_ace_'s Avatar
_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold_ace_ is a splendid one to behold
What is the PCV system? Not familiar with the acronym.
In other Porsches filling to the top and running at the track sometimes can end with the AOS getting overwhelmed.
Old 10-25-2017, 06:26 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
Positive Crankcase Ventilation
Sucks oil vapor back into induction system to be burned.
Don't fill it all the way reduces chance of oil being sucked up. Especially true when it gets hot ...oil expands in volume.
Elliot
Old 10-26-2017, 06:30 AM
Elektra's Avatar
Elektra is an unknown quantity at this point
Hi, Has anyone tried use bardahl?
