Steering problem
Old Nov 17, 2012 | 06:44 AM
braindoc1's Avatar
braindoc1 has a spectacular aura aboutbraindoc1 has a spectacular aura about
Steering problem
I was wondering if anyone has experienced a problem with feeling the steering mechanism " skipping" or "popping" when making a sharp turn at very low speeds. I notice it pulling in and out of parking spots; when it skips, the whole car jerks. It seems to be worsening over the last couple days.
Any thoughts?
Old Nov 17, 2012 | 07:03 AM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Not good and sorry to hear. I would take it in for sure.
ChuckJ
Old Nov 17, 2012 | 07:17 AM
Lostturbo's Avatar
Lostturbo has a spectacular aura aboutLostturbo has a spectacular aura about
Any thoughts?
Mine does the same thing.... I thought it was normal....
Old Nov 17, 2012 | 07:21 AM
opnielsen's Avatar
opnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond reputeopnielsen has a reputation beyond repute
Any thoughts?
It could be the tires and not the steering. When it gets colder the rubber compound will get harder and not stick to the road, try and see if this happens on a warmer mid afternoon day and after a drive where you got more heat in the tires.
I experienced the same in my 997.2 tt and then realized that it was only on very cold days where the car was parked outside on a parking lot and the tires and surface was very cold.
Old Nov 17, 2012 | 10:57 AM
I'mAllIn's Avatar
I'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud of
I would guess your tires are scrubbing / skipping. It's normal with a wide tire at low speed and sharp turns. I purposely try to avoid them and make as wide a turn as possible, such as when parking.
Old Nov 17, 2012 | 11:28 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
It's the tires. That "problem" when away when I switched my 20inch wheels for 19 inch wheels with winter tires.
Old Nov 17, 2012 | 11:30 AM
ChuckJ's Avatar
Good thought. Mine do that, but so has every other wide tired car I've had and I may just be used to it. I think the steering geometry is such that one tire's turning angle is actually a little different than the others during very tight steering, causing it to build traction, then release when it can't hold it any more.
Chuck
Old Nov 17, 2012 | 11:54 AM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
Any thoughts?
Do you have power steering plus?
Old Nov 17, 2012 | 03:12 PM
braindoc1's Avatar
Great thoughts, thanks. You may very well be right, it's certainly more noticeable now that it's cold.
No, fester, I don't have power steering plus.
Old Nov 17, 2012 | 03:37 PM
eagle_lex's Avatar
eagle_lex is infamous around these parts
definately the cold weather and your tires "skipping." i had the same thing occure on my c63.
Old Nov 18, 2012 | 06:44 AM
braindoc1's Avatar
Thanks! appreciate the input.
PV=nRT.
Sep 9, 2022 06:06 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
AdamNoone
Sep 3, 2015 04:12 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
