Anybody not keep there 911 in a garage
Old Jul 10, 2013 | 06:27 AM
Mig7410's Avatar
Mig7410 is infamous around these parts
I'm thinking about getting a new 911, but I don't have room in my garage for it. This car would replace my Boxster witch I used as a part time daily driver. I live in a safe neighborhood, my only worries are the elements of the weather and wildlife. My Boxster has held up good for the past two years outside, only the snow and ice has caused me problems due the the soft top and window indentation.
Old Jul 10, 2013 | 06:41 AM
frank69m's Avatar
frank69m has a spectacular aura aboutfrank69m has a spectacular aura about
Car cover?
Old Jul 10, 2013 | 07:20 AM
jaspergtr's Avatar
jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !
Mine wasn't kept inside. I had no problems with it in that regard (no cracking or faded interior, paint fading, etc...).
Old Jul 10, 2013 | 09:43 AM
OCT's Avatar
OCT
OCT is infamous around these parts
mine isn't kept inside, only car cover in winter since I don't drive it much
One thing should mention is the water spot...
Old Jul 10, 2013 | 10:31 AM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
Car cover too. I can't get into the garage due to steep drive. It does sit under a canvas carport, but still gets leaves and other debris. Just do not use the cover if the car is dusty, has debris, or the car cover is not cleaned. You can scratch the paint. Otherwise you should be fine. Arrive home from work or wherever, throw on the cover and you're good.
Old Jul 10, 2013 | 10:47 AM
jaspergtr's Avatar
Originally Posted by Chupacabra
... Just do not use the cover if the car is dusty, has debris, or the car cover is not cleaned. You can scratch the paint. Otherwise you should be fine....
This is wonderful advice about car covers. Period.
I would only use them seasonally (personally). But if you are able to protect it from the rising/setting sun, I'm sure additional protection is never a bad thing.
Old Jul 10, 2013 | 10:54 AM
JoeInDallas's Avatar
JoeInDallas is infamous around these parts
I once saw a bridge made from a thick sheet of steel, that was hinged in someones driveway. Presumably, so that it could be flipped down to get a low car up the driveway. When I saw it, it was in the flipped up position. It was easy though to tell what it was. Not so obvious though, as to be an eyesore. Might be a possible solution for you. Just a thought.
Old Jul 10, 2013 | 11:45 AM
Founder's Avatar
Founder is infamous around these parts
In the end, its sunlight that does the most damage over time. If you keep the car for 5 years or less you should be good - even then your paint WILL age much faster than it would indoors. Keep the car longer and it will be heartbreaking. I second the caution on car covers, the Tyvex ones can scratch your paint even if its clean.
If only they added SPF 50 to car wax!
Old Jul 10, 2013 | 02:26 PM
CarreraPete's Avatar
CarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud ofCarreraPete has much to be proud of
I'd consider using this product for extra protection against the elements: http://www.autogeek.net/optimum-opti-coat.html
Old Jul 10, 2013 | 02:42 PM
yxc145's Avatar
yxc145 is infamous around these parts
I used to get car cover for my cars. After awhile, you get too lazy to put it on and off. About 6 months.
I wonder what you got in your garage that you can't spare the room for a Porsche 991.
Old Jul 10, 2013 | 03:09 PM
PorscheCrazy's Avatar
Sorry, gotta agree here. Make room in the garage . . . .
Old Jul 10, 2013 | 09:26 PM
jaspergtr's Avatar
Maybe he's got a McLaren sitting there?
Dunno... Everybody has their priorities.
Old Jul 11, 2013 | 03:26 PM
SLVR_BULLIT's Avatar
SLVR_BULLIT is infamous around these parts
I agree... car cover when not in use. If it is a daily driver, you drive to work, it is outside all day (unless you work where there is covered parking). Then at night you drive home ( in the winter months it will likely be dark soon)... so not sure how much additional sun damage would happen by being stored outside.
Old Jul 11, 2013 | 03:48 PM
Nuke986's Avatar
Nuke986 has a spectacular aura aboutNuke986 has a spectacular aura about
Beware, car covers can damage your paint if put onto a dirty car... And outdoors the wind is gonna move that cover.
Old Jul 11, 2013 | 05:26 PM
very good point. As some have mentioned before, the 991 paint seems less resilient than previous models.
