Rear spoiler over the engine - when does it deploy?
My 2015 911 has a rear spoiler over the engine that is totally impossible to ever see while driving if it is deployed or not. I can check that it does work when parked if I deploy it on purpose. But it is total faith that is has deployed during driving. If it has deploys automatically, there is no way that I found to determine what position it is in. I also couldn't find any information about what speed is it suppose to deploy, and what speed is it suppose to close. Does anyone know some of this information?
Depending on the vehicle speed and the position of the slide/tilt roof, the rear spoiler extends automatically at above approx. 75 mph (120 km/ h) and retracts again below approx. 50 mph (80 km/h).
If you have a sunroof (and its opened), the spoiler deploys at an even greater angle. You can barely see the top edge of the deployed spoiler in your rear view mirror. http://www.porscheownersmanuals.com/...ting-principle |
As “dux” discussed, when engaged automatically, the rear spoiler obscures the bottom edge of view from the rear view mirror.
I have never checked my 991, but on my 997.2 I actually had my young son ride in the back seat and watch, and tell me when it went up (120 km/hr) and down again at 60 km/hr
it is a lot easier to see it on 997, but not 991. but if you move up a little you can see the upper edge.
Best way to see it is very late afternoon with the sun at your 3 o'clock low. Look at the shadow of the car at your 8 o'clock low. Easy to tell when deployed. Don't forget to check your 12 often!
I only bought my 991 2CS because I could see the spoiler go up and and up again and down too! If you have a cab, you need someone following you with a camera.
It will trigger a dash light if it does not work.
Originally Posted by chuckbdc
(Post 4672293)
On my 991S, I couldn't see it even if I sat up in my seat...with the GTS, I can see it deployed at the lowest angle. Maybe due to the wide body?
Originally Posted by chance6
(Post 4672991)
I believe that in the GTS the spoiler always deploys in the higher position that mine (C2S with SPASM) goes to when the sunroof is popped. |
Originally Posted by dux
(Post 4668730)
You can barely see the top edge of the deployed spoiler in your rear view mirror. http://www.porscheownersmanuals.com/...ting-principle I have tried many angles with my exterior and interior rear view mirrors and have yet in 5 1/2 years ever seen my spoiler ever go up or down automatically. |
Originally Posted by cfpchfc1
(Post 4672897)
Better view on a Turbo 991 :D:D
