Porsche PSE for 991.1 BASE need some help with installation
Old May 11, 2018 | 10:12 AM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Hello guys,
Need some help with installation, Im planning on getting the PSE installed with no console switch, just the valves open all the time but need some help, I've been told by my dealer Tech that this can be done if we removed the valves and get wire to tight the valves open all the time, I'll be getting the old mufflers out and installing the new ones and no vacuum lines, just checking if someone did it like this before and how it was done or maybe it needs to be done differently
Thanks for any help.
Old May 11, 2018 | 01:55 PM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
Put a golf tee in the vacuum line, well that is what we did with my Corvette years ago.
Old May 11, 2018 | 02:54 PM
solrac6262's Avatar
Thank you, been doing a lot of research and some guys from the GT3 sub forum thats what they do, I'll tell the tech no to disable the valves and just to plug the vacuum line, see if that works
Old Apr 2, 2019 | 06:47 PM
malahhaor's Avatar
malahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to behold
did you ever get this done?
1977jw
Oct 31, 2015 07:24 AM
socalsteve
Sep 29, 2014 03:26 AM
JLnike
Mar 23, 2014 02:42 PM
dk10438
Jun 22, 2011 06:53 AM
