FVD Brombacher | Part Focus | 991.1 Carrera| Sachs OEM Clutch Kit
Old Aug 23, 2022 | 02:00 PM
Rhonda@FVD's Avatar
Premium Sponsor
Rhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond repute
The 991.1 Carrera / S / 4 and Carrera 4S models have a self-adjusting clutch which increases the service life and ensures that the required pedal pressure remains constant over the life of the clutch. This clutch kit is a cost effective, direct replacement from ZF Sachs in Germany which meets the OE criteria. The kit includes all relevant components necessary to simplify assembly and ensure long clutch service life.
Kit Includes:
1 Qty. ZF Sachs Pressure Plate with XTend Technology
1 Qty. ZF Sachs Disc
1 Qty. ZF Sachs Release Bearing
1 Qty. ZF Sachs Race Engineering Grease for Clutch Installation - 3 Grams
Sachs XTend pressure plate ensures optimum transmission reliability of the engine torque to the transmission as well as the longest possible service life of every single clutch component. The technology provides automatic wear compensation by separating the wear of the facing from the movement of the diaphragm spring. The compensation mechanism constantly registers reduction in the lining and compensates for the created gap by reliably turning an adjustment ring. This keeps the clutch from becoming vulnerable to extreme temperatures, soiling and aging. Furthermore, the pedal-force conditions remain constant over the entire service life. At the same time, the service life is extended, since the facing can be worn down further. Another advantage of XTend is in its design: The installation space required axially in the clutch system with operational wear is reduced through the use of XTend.
The FVD Brombacher core principles of reliability, quality and OE fitment are perfectly aligned with ZF Sachs products. We have a tradition of offering German manufactured products that are easily installed, German made, TÜV approved (where applicable) and offer quality equal or greater than OE. Those high standards naturally led us to the ZF Sachs brand. Each ZF Sachs product is precision designed and manufactured to offer ultra-smooth drivability and the reliability that you expect from your Porsche.
991.1 Carrera | Part # 991 116 913 11 | $ 529 Retail | Details…
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Rhonda@FVD
997 Vendor Classifieds
Aug 19, 2022 01:09 PM
pwdrhound
Feb 7, 2017 10:05 AM
996 Vendor Classifieds
Jul 31, 2014 12:19 PM
RAU940
Oct 12, 2009 05:59 PM
MCM97
Jun 12, 2008 08:17 AM
