will these offsets fit on a 993tt?
i was offered a set of bbs e88 from another member. will this fit on a 993tt?
Here are the specs: Front: 18x9 44mm Offset Outer rim 1.5 in. Inner rim 7.50 in. Rear: 18x11.5 44mm Offset Outer rim 3.0 in. Inner rim 8.5 in. |
offsets
i my opinion, a very tight fit , both front and rear - you should be able to judge for yourself by making an offset diagram and comparing with what you are running on the car now.
