993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
Need feedback on this car...
Old Nov 22, 2010 | 03:53 PM
onlydrivefast's Avatar
onlydrivefast is infamous around these parts
Hey guys this is my first post on 6speed... I found a White low mileage 993 (Non-Turbo) in Huntington Beach. I was wondering if anyone on here knows any information on the car before I order a PPI and start my own research. Also, I was considering offering closer to $32K to start low, what do you guys think would be a fair price for the seller and me (If the car is perfect as he says I wouldn't want to steal it from him, but at the same time I want a good deal). Any feedback is much appreciated, here is the car - http://globalautosports.com/car/1996-Porsche-911Carrera-Coupe-31238.html
Last edited by GT3 Chuck; Nov 22, 2010 at 11:59 PM. Reason: not enough time as a member or enough posts/active link
Old Nov 22, 2010 | 04:46 PM
Bob993's Avatar
Bob993 is infamous around these parts
Car looks super clean, in the pictures... A PPI should give you most of the info necessary to make a knowledgeable offer... I'd start low and work my way up as necessary. Good Luck
Bob
Old Nov 22, 2010 | 05:55 PM
dfwerdoc's Avatar
dfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud of
you have great tastes .... highly desirable all the way around. if a ppi works and every part of that car except the stereo is original and you snag it for 32k jump on it.
Old Nov 22, 2010 | 06:20 PM
TorqueChap's Avatar
TorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud ofTorqueChap has much to be proud of
+1. gorgeous car! GL with the purchase and fully agree on a PPI first to save you headaches down the road
Old Nov 22, 2010 | 10:21 PM
What would you expect a PPI to run? I am hearing $125 - $650. What have you paid, and what was performed/checked?
Old Nov 23, 2010 | 03:45 AM
dfwerdoc's Avatar
here you go ... here is your ultimate ppi; 300 to 500 i would say.
ECU/DME
- (OBDII) read fault/readiness codes
TEST DRIVE
- full throttle in 2nd (once warm), ensure 0.8bar boost (not "limp home mode") and check for clutch slippage
- idle at 880 +/- 40rpm
- make sure no stall on quick stop with A/C on
- check for wheel rub (full left/right lock while forward/reverse)
- test ABS (ABD if possible)
- watch temps.
- Ensure oil thermostat opens
- listen for oil cooler fan speeds at stop
- Check braking (no shudder/squeal/pull to either side)
- Ensure smooth power steering
– downshift into 1st at ~15mph to ensure easy engagement, no odd noises
- upshift and downshift into 2nd at a variety of speeds, ensure no crnchiness or notchiness
TURBOS
– check for oil leakage
- look inside pipes (turbo to intercooler) for oil
CLUTCH
– ensure no “clicking” or “hanging up” in clutch pedal motion (engine stopped and running)
- no signs of slippage
- accumulator
- check for hard pedal before start
- check for pentosin leaks from accumulator/slave
DRIVETRAIN
- visually inspect rear diff., viscous coupler, front diff. (for leaks, damage)
- check rubber CV joint boots for tearing/cracking
ENGINE
- compression test all six cylinders
- perform a leakdown test on all six
- check serial number – should begin with “61V” (1996) or "61T" (1997)
- check distributor, coil(s), plug wires for visible damage
- check engine tray (if installed) for oil deposits
- check for all fuses/relays (match w/ diagram on box cover)
- check valve covers, timing chain covers for leaks
WARNING LIGHTS
– all come on with key on, extinguish upon start
- make sure CEL not tripped (check OBDII to rule out removed bulb)
-check LCDdisplay on OBC for full functionality
CLIMATE
- A/C blows cold
- heat blows hot
- all climate control functions work (buttons/switches functioning)
STEERING
- check steering rack for leaks
- check rubber boots for tearing or cracking
- inspect p/s pump for leakage
OIL LEAKS
- check under engine
- timing chain covers
- lower valve covers
- smoke on start?
- smoke once warm?
MISC
- tool kit present
- jack present
- air compressor present
- door locking (from all switches and remote)
- alarm
- number of key fobs
LIGHTS
- driving lights
- head lights
- tail lights
- 3rd brake light
- fog lights
- interior
- trunk/engine lid lights
- glove box
- all turn indicators, including hazards
BODY
- check for rust, especially near bottom corners of windshield seal and around seals
- remove headlights, check forimpact damage/paint work/metal work
- any signs of impact damage
- check for even gaps either side of hood, trunk
- ensure engine bay stickers
- ensure sticker under luggage compartment (trunk) lid
- level “turbo” badge
- inspect for rolled fenders
- if possible – paint thickness meter?
- check for repainting/overspray around plastic, in door jams, etc.
- trunk
- look for corrosion (beneath fuel tank, brake reservoir, around bolts)
- check under spare wheel for rust, ensure drains OK
- look at ABS/ABD control unit for corrosion
- inspect for paint damage beneath hydraulic components
- check for small cracks in front bumper (should exist on 11yo car)
- install tow hook – should thread evenly and straight
- check taillight (condensation)
- remove rear bumper (front also if not too time consuming), check for repaint/metal repair underneath
- check seals (pour water down leading edge of doors, sunroof)
- check door for missing, clicking, loose straps/stops
INTERIOR
- check condition of vinyl/plastic/fabric
- check function of electric, heated seats
- power windows (ensure every switch works)
- test front wipers at all speeds (including delay)
- check windshield and headlight sprayers
- ensure function of rear wiper (if installed)
- defrost
- rear window, windshield, outside mirrors
- electric mirror controls work
- check AM/FM/CD/tape(?) for function
- check clock for function
- ensure sunroof opens, closes
Old Nov 23, 2010 | 06:40 AM
Dunit's Avatar
Dunit is infamous around these partsDunit is infamous around these parts
Ppi
The car looks great. I would highly recommend taking your car to http://www.hergesheimer.com/ for the PPI. Good luck with your purchase.
Old Nov 23, 2010 | 11:46 AM
Wow! dfwerdoc, you just made my life easier... I am going to print this out and have each item checked off one by one. I can use this as a bargaining tool as well. And Dunit, I will consider taking it to the place you recommend the PPI be done at.
Old Nov 23, 2010 | 11:08 PM
MJ3's Avatar
MJ3
MJ3 is infamous around these parts
Good luck
Let us know what you end up deciding on.
Old Dec 7, 2010 | 10:20 AM
ronev's Avatar
ronev is infamous around these parts
Beautiful car....Good luck!
matt2ace
Nov 23, 2019 11:38 AM
takenotes996tt
Jan 20, 2016 06:34 AM
FUTURESTAR
BMW //M
Nov 18, 2015 10:37 PM
XLR82XS
Sep 26, 2015 01:46 PM
