question for the 996 turbo owners
Old Nov 5, 2007 | 01:37 AM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
need some help guys..... my car bogs when it hits boost what could it be? it runs fine under 3k rpm if i go pass it the car bog and then i see .3 bars then bog and then jumps to .5bars.... does that mean i have a boost leak or maybe a bad maf sensor. thanks in advance guys
Old Nov 5, 2007 | 02:23 AM
Beej's Avatar
Beej is infamous around these parts
Hi - sounds similar to problems I had recently which turned out to be a leaking boost hose/pipe and a faulty MAF. Eventually CELs will start coming on.
Cheers,
Beej
Old Nov 5, 2007 | 03:35 AM
ckm88's Avatar
ckm88 is infamous around these parts
You could also be running rich...any mods?
Old Nov 5, 2007 | 11:04 AM
Zbolts's Avatar
Zbolts is infamous around these parts
Hey ckm88 - Didn't you and your Daddy just get your car?
And you're already giving advise....Truly Amazing! The learning curve here at 6speed is incredible.
Melsta, is your ECU stock? If, so you might have a boost leak. If you have flashed it recently, you could be overboosting. Other than that you might have MAF issues. I recommend the obvious - have it checked out by a trusted Porsche technician.
Old Nov 5, 2007 | 11:33 AM
melsta's Avatar
Thanks guys
I only have bov and exhaust on my car with no ecu upgrade yet. its throwing code 1128 and 1130 I look in the repair manual for those code and it says check either maf or fuel pressure and the fuel pressure is at the correct psi. I have the evom hoses that I am gonna put it on to see if it will fix the problem.
thanks for the replies I just want to narrow down the possibilties before I go and get rip of by the dealers
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Aug 19, 2015 06:55 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
