weird boost pattern?
anyone else experience this? im just hoping its the 38 degree cold weather affecting it as its never happened before but in second gear i dont boost right. it starts to stumble and only boosts around .4-.5 but once i shift to third it goes back up to .6-.7.
ive never had this happen before and the temp suddenly dropped 20 degrees here literally over night. any suggestions on what might be causing it?
Nope... not a single code was being thrown at me... so i was a bit clueless.. i guess ill try it out again today. it wasnt consistant. it happened two of the 10 times i did a sprint down the street.
When my MAF went, it would stumble and sputter, and then take off as the RPM increased. It acted like the plugs were fouling.
So I purchased a new MAF off E-Gay. Once installed (5-minute ordeal) the care runs like new.
If the MAF needs replaced, be sure to get the connection installed correctly or you will end up seeing a PSM\ABS failure displayed.
im guessing the last time the plugs were changed were about 10,000 miles ago with a major service done to the car at 30,000 miles.
after fiddling around, it only happens when im shifting from 2nd to 3rd at WOT. If I start in 3rd and go WOT, then i get my solid .6 but when i shift from 2nd to 3rd at WOT, it stumbles to .5 and i definitely feel the difference...
Get the codes read...this was already suggested. Your car does not have to have any dash lights for codes to be registered. Either get a code reader (durametric) or take it somewhere to get it read (autozone or dealer)...this will help with diagnosis.
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
