Replacing Battery
Old Jun 14, 2004 | 01:59 AM
Rob's Avatar
Rob
Rob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of light
Replacing Battery
Is there a specific procedure to follow when replacing the Turbo's battery? I did a quick search, but couldn't find anything. TIA
Old Jun 14, 2004 | 02:55 AM
rspiteri's Avatar
rspiteri is infamous around these parts
I did it a few weeks ago. Piece of cake. Jusy open the hood remove the middle cover closet to the wiper baldes. Remove the holding bracket left of the battery. The new battery comes with instructions on the sequence in removing the terminals. You will need to recode the radio after. It took me 15 minutes and I was just being carefull.
Good luck.
Old Jun 14, 2004 | 03:17 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
yup...5 minute common sense procedure
Old Jun 14, 2004 | 03:35 AM
Rob's Avatar
Rob
Thanks fellas, I asked because I thought I remembered something about leaving the drivers door open, not having the key in the ignition and then letting the car sit for like 10 minutes before starting it. No truth to any of this?
Old Jun 14, 2004 | 03:51 AM
CAPTLST's Avatar
CAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond reputeCAPTLST has a reputation beyond repute
There was something in the owners manual about hooking up one of the terminals first. Check the manual and it will give you detailed instructions.
Eric
Old Jun 14, 2004 | 04:22 AM
Pistol's Avatar
Pistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these parts
screw all that
go to your local pep boys, buy a red top Optima battery and go to a Porsche shop and have that bad boy installed. The Optima will not leak and is a longer laster. Also has a self trickle down system
Old Jun 14, 2004 | 10:35 PM
racer63's Avatar
racer63 is infamous around these parts
Pistol,
How'd you mount the Optima? I used the factory mounting bits and it seems pretty dicey to me. I definintely would not take it out on the track this way. Around town it is probably ok...
Old Jun 15, 2004 | 01:14 AM
JayM's Avatar
JayM is infamous around these parts
You definitely need to make a couple of mods to get it secure. This guy has a pretty good set-up (albeit for a Boxster) and is what I plan to follow when I install the yellow-top currently sitting in my garage (work keeps getting in the way of the truly important stuff )
http://www.brackenrig.net/Other/optimainstall.PDF
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
