How many Hps can the factory internal of 996TT hold?
Old Feb 20, 2008 | 05:07 AM
chenshan's Avatar
chenshan is a jewel in the roughchenshan is a jewel in the roughchenshan is a jewel in the rough
600? 650 or 700 crank? Is there anyone aware about this? Thanks in advanence!
Chenshan
Old Feb 20, 2008 | 06:14 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
This has been brought up many times, do a search.
I think most believe 600whp, but I have seen 700+ whp (Jamies GT2). Not sure how long that will last though....
https://www.6speedonline.com/forums/...ad.php?t=76715
Old Feb 20, 2008 | 07:22 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
600HP coupled with boost under 1.2 bar and high octane gas should give you the most reliable combination.
Old Feb 20, 2008 | 07:48 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
About 700 crank HP or 600whp (on good gas) or about from what I've been told for longevity (sp?) purposes you want about 575whp max on pump gas. Anything more than that is pushing it. These are the numbers I'm shooting for safety purposes.
Old Feb 20, 2008 | 08:05 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
It depends a lot how you use the car.
I wouldn't go much past 600hp myself. A lot of track and autobahn driving here. The German tuning companies start opening the engine after 600hp and that might be the reason why I see only few tuning kits from Germany in this forum if they are within the same power but cost more.
Actually, the tests against different cars we've made tell that European tuners might offer more speed with the same stated numbers
Many here seem to have no problems with 700hp so do as you like
Old Feb 20, 2008 | 08:10 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
I would not go past 625 crank hp on stock internals, just not worth the risk IMHO
Old Feb 20, 2008 | 08:49 AM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
That's a pretty complicated question. I think it goes beyond raw HP number to how the car is actually performing.
Which is more likely to go first:
A 600hp car at 1.5 bar of boost running lean with EGTs off the charts
OR
A 650hp car at 1.1 bar with a steady 12 AFR?
I'll take that 650 car any day of thew week. Of course, if the car is making clean power but there's just so much of it that it's bending rods, that a whole nother animal.
Old Feb 20, 2008 | 08:55 AM
chenshan's Avatar
thanks!
Did you change your internal under your 700+ setup?
Old Feb 20, 2008 | 08:59 AM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
I the early days the opinion was that 600 hp was the limit but it is now known that they can withstand a lot more.I know of one 996tt that is over 700hp and runs on pump gas @ 1.5 bar and over boosts @1.8 on stock internals.
Old Feb 20, 2008 | 09:04 AM
chenshan's Avatar
I always wander whether RUF 600+ cars do change interanl or not.....
Old Feb 20, 2008 | 09:10 AM
chenshan's Avatar
WOW~~~~1.5-1.8bar!
Could you tell me for how long this beast surviving?
Old Feb 20, 2008 | 09:27 AM
Neil@Orton's Avatar
100% a ok. The engine was removed this week and got a clean bill of health.The car has had the S**T beaten out of it for the last 15 months and it red lines at 8k
Old Feb 20, 2008 | 09:32 AM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Nice!
Old Feb 20, 2008 | 10:06 AM
chenshan's Avatar
Can you tell me what's the turbo this car using? What's the setup? I am trying to get a 700+ setup but was told not to boost up over 1.2 bars by pumping gas.
Old Feb 20, 2008 | 10:42 AM
Neil@Orton's Avatar
K24 based garrets + 990cc injectors and a few other bits
