Clutch problem: 1st gear, clutch all the way to the floor but not totally engaged.
Old Feb 20, 2008 | 02:03 PM
arr0gant's Avatar
arr0gant is infamous around these parts
Just got a brand new clutch and linkage a few weeks ago. Put about 700 miles on it since then, it's been great.
I started noticing, after I drive for a 10 to 20 yards with the clutch all the way out, in 1st gear, then when I engage the clutch and come to a complete stop it still learches slightly forward (as if the clutch is let slightly out and its grabbing gears). I really have to pull it hard to get it out of 1st, then I put it back in 1st and it's fully engaged and working fine. It only does this sometimes. It think it may do this in reverse, also.
The weather is sub 30 degrees farenheight.
Any ideas?
One more thing. It takes me 4 or 5 times (of driving 10 - 30 yard and stopping) for it to actually get it to do this.
Old Feb 20, 2008 | 04:10 PM
Turbo Fanatic's Avatar
I had this exact situation in my stock M3. The clutch would not disengage fully and "drag". The result is a burned clutch/flywheel that looks a LOT like abuse when you take it apart.
It took me months to convince BMW that their $hit was defective and got a warranty repair. The syncros never fully recovered from having to force the gears with the clutch fully depressed. It was at its worst when trying to engage first from a dead stop.
Barring a condition caused by the super low temps, I would not drive the car and get the issue fixed immediately.
Old Feb 20, 2008 | 04:35 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Sounds Like a slave cylinder.Sometimes you need to bleed the fluid, could be air in there, and could very well show up awhile after.Get it checked before your burn the clutch
Old Feb 20, 2008 | 05:45 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Check the slave for leaking. If that's not it, bleed for air in the lines. Chances are it's one of these two issues.
Old Feb 20, 2008 | 05:46 PM
kilrgt's Avatar
Graet minds think alike....
Old Feb 20, 2008 | 06:34 PM
if the pedal drops you probably have a leak... check ur car underneath....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 20, 2008 | 07:51 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
noob question - Where is the slave??
Old Feb 20, 2008 | 08:34 PM
John D's Avatar
I actually meant the master cylinder could be leaking, which is in the footwell area at the top of the clutch pedal. The slave is on the top of the transmission...reached from under the car. So you could look for fluid in the upper footwell area or under the car. It only takes a tiny leak to cause problems - a leak so small that you may not see dripping fluid very easily...
Old Feb 21, 2008 | 05:53 AM
cohare's Avatar
So can you bleed/change the slave with out taking out the tranny?
Old Feb 21, 2008 | 07:02 AM
John D's Avatar
From what I have been told, the bleed is no problem, replacement is a little difficult, but doable.
Old Feb 21, 2008 | 09:48 AM
arr0gant's Avatar
Thanks so much guys! Before I call my dealer, do you guys think this is something to do with them installing the new clutch a few weeks ago or probably unrelated?
Old Feb 21, 2008 | 09:55 AM
John D's Avatar
Did they put in a new slave or master? If so, it could be bad or maybe the system requires a bleed. I guess it could be other issues with the install, too...
Old Feb 21, 2008 | 03:26 PM
arr0gant's Avatar
I don't think so. I'll be taking the car in on Monday. Thanks guys!!
Old Feb 21, 2008 | 06:39 PM
05evo8gsr's Avatar
05evo8gsr is infamous around these parts
Do Porsches have an adjustable clutch pedal? You might have to adjust the clutch. I had a problem like that when i first put in my twin disk clutch. I had to adjust the clutch pedal for it to engage right
Old Feb 27, 2008 | 03:29 PM
arr0gant's Avatar
So, the dealer could not get it to reproduce the problem. I picked up the car, drove 20 minutes back to work and it was fine....so, well see.
Thanks for everyones help!!
