Wheel Hop
Old Mar 15, 2008 | 08:00 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Yea I agree with Dmaffo, be careful with wheel hop, it can hurt your pocket...ask me how i know.Its most likely the tires with a combination of running a 19" and I don't care what anyone says 44 PSI is too much.
Old Mar 15, 2008 | 08:49 AM
jagsiva's Avatar
jagsiva is infamous around these parts
What would you recommend for rear tire pressure?
Old Mar 15, 2008 | 06:05 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Originally Posted by STEVE KOJASEVIC
i have 44lbs in the back aswell
no hopping issues whatsoever
315/25/19
Hi Steve, All the time we spent on adjusting the rear upper control arms and shock valve setting is what stops the wheel hop. Tire psi, inner rim bend, helper springs, no sidewalls or to stiff. I can go on but I have spent a lot of time trying to get the 996 platform to hook up. I have found that the 44psi keeps the sidewall from flexing (stops the sway) in the turns remember the motor is in the back.
Tim
Old Mar 15, 2008 | 09:21 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
Hey T... what susp set up you running???
Old Mar 15, 2008 | 09:41 PM
kilrgt's Avatar
I run Bilstein Sport Shock , with HR Lowering springs, I also went with GMG GT sway bars. The front sits a little high for my liking I think I am going to go with some coil overs.I also run a 19" for my street driving and some BBS LM for my track days.
Old Mar 16, 2008 | 10:26 AM
Staff@RPM's Avatar
Hi, I run PSS9's stock sways thats for 1/4 and mile runs. for 1/4 I run stock ride hight and drop it for the mile. I am working on my setup for the track. The alignment is key it changes for every application.
Tim
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
