New Swaybar Project - Road Racers Opinions Wanted
Old Mar 28, 2008 | 05:12 AM
topcat4's Avatar
topcat4 is infamous around these parts
Originally Posted by deandob
Yes, more info please if there is an Australian option.
What does this actually do that a tighter swaybar won't do? Is it complementary to a swaybar upgrade?
The movement in the std factory rubber bushes results in significant toe and camber change. The sway (anti-roll) bar is primarly to control the body roll, and while reducing the body roll will help a little towards reducing the toe and camber changes getting rid of, or reducing the movement in the bushes makes a much greater improvement in the handling.
Old Mar 28, 2008 | 05:16 AM
topcat4's Avatar
Originally Posted by MGS996TT
Further to my post....Topcat4 are you replacing the lower control arm bushing ?
Comments appreciated.
Depending on the application, the ultimate is to run the 2 piece RSR lower rear arm with the solid castor bush and the inner monoball, other wise we run a 2 piece control arm with a stiffer rubber inner bushing and the solid castor bush.
Old Mar 28, 2008 | 05:18 AM
topcat4's Avatar
I omitted to mention that the bushing and toe arm upgrades by no means negate the advantage of having better (and adjustable) sway bars.
Old Mar 28, 2008 | 08:19 AM
tom kerr's Avatar
Originally Posted by FAST FWD
Tom -
I've been thinking about the rear toe links. What's the advantage?
Jon
keeps the rear toe correct and replaces the rubber with a fixed ball that wont give or change toe in corners.
Old Mar 28, 2008 | 08:33 AM
Evader's Avatar
Evader is infamous around these parts
Originally Posted by CarNerd
If you run an aggressive alignment and good wide (305+) rear tires, even with an adjustable sway set at full stiff, you should really only be seeing snap oversteer if and when you lift off, which you shouldnt be doing anyways.
I generally agree but, when your car increases in torque by more than 250wtq within 500 rpm there is a sweet spot that can easily be overstepped....it was my EVO I was talking about as I have not tracked the 911 any. I run 275s all around with D compounds and 2 degrees of camber, the car is decently dialed. I have a bad habbit of throttle mashing and find that loosening up the sway allows the car to move a little and gives the tires time to stick.
IMHO each driver needs to find their own flaws, learn how to get away from them and try to dial thier car in to suit their driving style. Suspension tuning is not a one size fits all from my perspective.
Old Mar 28, 2008 | 09:18 AM
vividracing's Avatar
Evader... you are right. Many people have their own technique and need to find their weak spot to improve.
Jul 29, 2019 11:13 AM
dc3843
Aug 22, 2015 09:33 AM
pwdrhound
Aug 20, 2015 05:54 AM
Phoenix604
Aug 19, 2015 10:39 PM
Nissan GTR
Aug 19, 2015 02:11 PM
