Confused and Tired.. High RPM Idle
Where exactly is this?
Yes, absolutely,and then you can feed the air right before the TB in the small nipple located on the y -pipe.That will test everything after the turbos.The same symptoms can also occur if you have a leak between the maf and the turbos because air is entering the system that is not being read by the maf.Plug both ends and test to 15psi.Good Luck!
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
10-06-2015 03:43 PM
turbotuner20v
09-11-2015 12:02 PM
