-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   Almost There, New Symptoms. Won't Boost All The Way (https://www.6speedonline.com/forums/996-turbo-gt2/129962-almost-there-new-symptoms-wont-boost-all-way.html)
r34dy2walk May 13, 2008 04:59 PM
Okay. Last week I had an Idle problem. 0507, found out I had a intake leak under the intake manifold for the bypass valve or whatever. Same goes for the Intercooler Piping. Got that fixed. Car idles fine, no issues there.
Now I can't go past .7 bars of boost. I checked my wastegate and the vacuum line is still on pretty tight and the setting hasn't been changed on the wastegate itself. It just won't boost past .7 bars whereas it should be closer to 1.2-1.3.
This all happened when under hard acceleration. It cause the vacuum line to pop off or something under the intake manifold. I fixed that and still can't boost past .7 bars. I thought it was limp mode so I disconnected the battery for about 30 mins and still nothing. Its a nice steady climb to .7 bars, about .8 bar spike as soon as I let off the gas. Does this for all the gears besides 1st.
I'm running the EVO Wastegate, Forge Diverter Valves. Both fairly knew with only a few thousand on both. Got both this year.
HELP!
markski@markskituning May 13, 2008 05:20 PM
if u didnt have this issue before u had the problems solved then someone had to touch something and or disconnect.... especially since u disconnected the battery and still no go...
who did the work?
r34dy2walk May 13, 2008 08:07 PM
Well no. This all happened (boosting only .7, idling rough) at the same time after a hard acceleration. It started having boosting problems same time i had an air leak in the intake.
markski@markskituning May 13, 2008 08:47 PM
then you didnt fix the real issue... whatever that may be....
did u change anything else.... ecu? dvs? ect?
r34dy2walk May 13, 2008 09:54 PM
No. Nothing else was changed. Just reattached the popped line back into where it belong. Nothing else was done.
r34dy2walk May 14, 2008 02:00 PM
Shop called, they have no idea.... Can you believe that? They have no clue...
boca996tt May 14, 2008 02:11 PM
you have stock turbo's on it?
r34dy2walk May 14, 2008 02:20 PM
K24's
unvmy996 May 14, 2008 02:34 PM
if u cant figure it out your in Nj take it protosport.
r34dy2walk May 14, 2008 03:45 PM
The shop didn't know how to do a pressure test... Go figure.
Anyway, I need to find that thread so I can go out and make my own or something.
Staff@RPM May 14, 2008 03:54 PM
Hi, Hope you get to the bottom of this.... Tim
r34dy2walk May 14, 2008 04:39 PM
Want to help? :)
r34dy2walk May 14, 2008 04:45 PM
When doing a battery disconnect, you only need to disconnect the negative correct?
unvmy996 May 14, 2008 06:56 PM
yeppers
r34dy2walk May 14, 2008 07:01 PM
I guess i'll give the battery reset one more try. I'll just leave it disconnected for the whole day and attach it tomorrow and see what happens.
As far as I know ECU's cant be reset unless I rewrite it so we'll see. If I still can't boost past .7 bars I'll assume is a boost leak.
If it is indeed a boost leak that only appears under pressure, where would I look. Diverter valves, wastegate, f-hose... anything else?
