sg700
Old May 14, 2008 | 10:36 PM
tws_andrew's Avatar
tws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to all
sg700
Looking at a car with the full sg700 with gt28s. Any opinions? I see that it is a good value but I don't see any 60-130 times or trap speeds. Need some input. Thanks
Old May 14, 2008 | 11:43 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
I'm happy with my SG650. Have you driven it? What do YOU think?
Old May 15, 2008 | 07:23 AM
WOODTSTER's Avatar
Should be similar to GT700 (although there are some differences in fuel system
and ECU work, I believe). Should be an extremely fast car. They tend to run lean
(yikes) and I would check into this aspect of the car under boost.
MK
Old May 15, 2008 | 07:25 AM
LUISGT3's Avatar
SG700 uses stock fuel system. (GT700 does not, this is part of why the GT700 is more $)
They use the similar GIAC files.
They use the same Turbo's.
There are a few other special ingredients into a EVOMS GT700 that make it different.
Check out the 1/4 mile 60-130 thread. There may be some SG cars in there.
Old May 15, 2008 | 08:34 AM
Ice's 996tt Cab's Avatar
Ice's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura aboutIce's 996tt Cab has a spectacular aura about
I own the SG700. It's unreal!!! Super Fast!!
It had run lean but it has been fixed and it never had a problem since.
I have not done any 60-130 times with it, but it is hella fast!!!
Great Value also.
Recommend highly!!!
Ice
art4iza
Oct 14, 2008 05:00 AM
NineNineSixTT
Oct 12, 2008 07:13 PM
pnoob2
Jun 1, 2008 05:54 PM
pnoob2
Apr 29, 2008 12:46 PM
NMT
Oct 31, 2007 02:57 PM
