Repair cost: 996TT Timing chain tensioner?
Old Jun 27, 2008 | 08:58 AM
catfishez's Avatar
catfishez is infamous around these parts
I'm just curious if anyone has had a timing chain tensioner replaced by the dealer on a 996TT.
I'm limited geographically in my options and feel the dealer (100+ miles away)may be my safest bet . So please post a figure if you've had the work done.
While on the subject: Is this a common failure with a 2001- I'm pretty sure its the tensioner, as it gives the death rattle on a cold start-up and clicks away at idle. it goes away as the revs rise above 1500 or so.
One more question: Does the 996TT have hydo-lifters and solid valve lifters?
Old Jun 27, 2008 | 09:20 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
from what i know all 996tt have this sound !
Old Jun 27, 2008 | 10:57 AM
ard's Avatar
ard
Do a search here on the issue. Seems to be a spectrum of how noticeable this noise is based on luck of the draw. I've yet to see a definitive answer on why this is different or what causes it..or what is acceptable!
A
Old Jun 27, 2008 | 12:26 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
If you mean the pulley tensioner, its a pretty cheap part. There's 3 of them, 2 that are the same part #, they are under $100 each.
As far as labor, you need to remove the intake, and move the y-pipe up just remove it....
Old Jun 27, 2008 | 02:36 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
All TTs make that noise. Top off your oil with some Mobil 1 15W-50 and the racket diminishes significantly.
Old Jun 27, 2008 | 06:05 PM
catfishez's Avatar
thanks-I'll try the 15-50W:
I'd love to believe that the noise is just one of those Porsche 911 idiosyncrasies.. but it's really hard to build confidence in the car with this noise!! It seems to eat away at my very will to live every time I drive it:
Thanks for the advice and I'll be researching this issue without abandon.. I'm tired of missing track days, cruises and even trips to the drivethru over this unsettling racket!
Old Jun 27, 2008 | 06:14 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi.. Check your oil psi at idle. Also what is air temp. The 996 TT's have hydraulic buckets. Tim
cinellipro
Dec 20, 2017 07:12 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
takenotes996tt
New Member Introductions
Sep 3, 2015 10:12 AM
tkebp1275
Aug 31, 2015 06:35 PM
