What is the weight of a stock hollow spoke twist wheel?
Old Sep 6, 2003 | 06:13 PM
racer63's Avatar
racer63 is infamous around these parts
I am looking at aftermarket wheels and, for comparison purposes, I'm trying to find the weight of the stock hollow spoke twist wheels that come on the 996TT. Anyone know off hand?
Thanks in advance,
Old Sep 6, 2003 | 08:40 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
Re: What is the weight of a stock hollow spoke twist wheel?
Thanks in advance,
Aprox. 22 and 26 lbs. front and rear, respectively.
Old Sep 6, 2003 | 09:30 PM
Joe Weinstein's Avatar
I wish they published rotational inertia too...
I wish they published the rotational inertia too. Two wheels
with identical weight might have different weight distributions
that would help or hurt acceleration. Maybe not as much
as for motorcycles for instance, but I'd be interested to know...
I once replaced one of the early cast 'mag' wheels on a Yamaha
RD400, with a custom spoked wheel, and the replacement wheel
+ sproket (nylon!) + tire together weighed less than the original
wheel alone!
Joe
Old Sep 6, 2003 | 10:20 PM
racer63's Avatar
Thanks Jack.
How do you measure rotational inertia Joe? Just curious...
Old Sep 6, 2003 | 10:44 PM
KPV's Avatar
KPV
racer63,
You don't exactly "measure" it. You would need measure the intricate dimensions of the wheel's cross section and then the rotational inertia can be "calculated" using appropriate "mechanics of materials" equations.
As a rule of thumb, the more mass you have closer to the outer diameter, the greater the rotational inertia (bad). The less mass near the outer diameter, the lower the rotational inertia (good).
This is why, in general, I prefer wheels that have tapered spokes that are widest near the hub and narrowest near the rim edge.
Old Sep 7, 2003 | 10:46 AM
measuring rotational inertia
You would measure rotational inertia on a dynomometer
designed to do that. The test would be to measure how
long it took to spin the wheel from 0 rpm to XXXX rpm,
given a constant sourcce of power. Someone could probably
rig a test up with an axle on a stand, and an electric motor,
and the stuff to time-to-rpm. I'm not sure how much practical
info this will garner, but it would be of interest to know...
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
RS GT3 RS
Sep 24, 2015 09:27 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
