Clutch feels weird, not smooth
What else??
As you grow into the car and increase your driving skills, I'd expect you to want to COOL the fluid in the trany. Youll eventually KILL the tranny by overheating the fluid. I think you should talk to Kevin, or the guys at Douherty.
The mod Tom Kerr did to his car is absolutely what should be done to every 996TT tracked at or beyond the "blue run group" level if you don't ever want to rebuild that trans!
Mike
Mike
I see all the cheap auto tranny coolers and spending 2+k on a cooler just seems nuts.....but, the fluid is a lot thicker in a manual tranny or so I have been told. Here is the 100pt question: how do you pump the stuff reliably...?
I can get all the parts together for 500 or so it seems, best of breed perhaps.....it seems like a simple job if you have a lift/expertise...save getting metal shavings INTO the tranny if you tap it...so, the time to have done a cooler was when I had the unit apart.
For my part, that will be evaluated in time. Now, I am not good enough to need such. I'll change fluids after every other DE weekend or at 15k mile points. Leftecknic sells Delvac for 50$ a gallon....the way to go IMHO.
I fully agree....a cooler is something I want a lot...but I have to prioritize...2k is my estimate for a good unit that is bulletproof (to my standards)....like the on by S-CAR-GO posted here many moons ago.
That was a nice unit IMHO.
Now, there is tape or paint you can get to tell you how hot brakes get. It would be interesting for someone to get that stuff, put it on the tranny in various places, and report back....how hot does the thing get?
JB
JB
Guys thx a lot for the great info on the replies. I tried pumping my clutch and it does gets a little harder with time but didn't get rock hard at 25. Will try it again after letter the car sit for 2 days. Just found out I need new tires hehe so I can't drive her. I'll be willing to do a GT2 conversion on the car. Will try and get more info onto that. If changing it back to stock and waiting or it to happen again, i'll go for the extra few pennis.
And I assume you need a life to work on the car while changing this?
There is discussion about removing the tranny to do this particular mod, but Im' not sure, since I've been told and read here that you had to remove axles and starters and such to do the hydraulic slave, and I didn't have to do any of that...
I'd not do a slave replacement on hack stands... That would be a royal PAIN IN the ****!
Mike
Mike
DAS felt it was 3-5. PorschePhD told me 5 hours for a first time try by an experienced person, less for SK obviously...by a lot.
Guru is likely 3-4 (SK). DAS will likely be 4 hours. FYI. Tranny comes out. Nothing else.....and perhaps not "all the way out..." GT2 goes in on 11/21. I'll report back.
I'd love to do a cooler, but there is a lot of FAB work according to Bill at DAS. IF someone had a kit to do it pre-made, I'd be all over that. Anyone know of a tranny cooler "kit" where it is bolt on?
JB
JB
Just an update, my accumulator and slave cylinder.
First impressions, holy crap I didn't know the clutch can feel so smooth "watery". It's so much easier to drive and change gears now. Also with this change, I added the evo short shift, and it feels so good to change gears now. Really precise.
Thx fort he tips on what my problem was, took the mechanic about 3 hrs to do it.
Again thanks a lot.
Again thanks a lot.
I had to bring this back up...I wouldn't say I have a major issue with my slave but it feels like half way down the pedal it has a little hesitation until I push through it to the floor. Is this the same issue? The pedal isn't too hard or anything, it feels like it needs a little grease, lol.
So what part number do I want GT2? How much is it exactly through the sponsors on the board?
Have you found the issue?
on my car it was accumulator - I replaced it on my garage floor, a bit of a pain but not bad. lol
it was hard to press. I also have clutch slave cylinder and slave cylinder as spare , just in case.
pshep138
09-01-2015 09:45 AM
hacellular
08-31-2015 08:34 AM
