60-130 times with proto intake & 20g's
hey guys
major problems getting the car to hook up tons of wheel spin and i'm AWD...coming out of second it goes completely sidewayshilarious 7.4 sec 60-130 with todds base tune doing some tuning this afternoon i may turn down the boost and see what it will do tim |
WOW....The car spin from 60mph???
7.4sec with spin..That's quick!!! |
Tim,
If you can hook up, in cool weather you should be below 6.5 easily. I recommend switching to an R compound tire. |
There's something wrong with your PSM hilarious Hope you can hook!
you need MT drag radials or BF goodrich in the back otherwise you will be dissapointed...
it is too cold in the midwest right now to hook up at... Also, you will need those ICs cause stock just will not do... I have seen 5s in Bobby's old car... but it was well set up ... |
Originally Posted by colorinc
(Post 2130496)
hey guys
major problems getting the car to hook up tons of wheel spin and i'm AWD...coming out of second it goes completely sideways tim |
I have some Toyo RA-1's you can try out if you want. :)
My PS2's have been in the attic since the 993 came back from Arkansas- nowhere near enough grip. |
How would you compare your new k24/20g to your previous setup's power, spool and top end? Is it even more brutal than the 18g?
lsd
(Post 2130496)
hey guys
Originally Posted by Dr_jitsu
(Post 2130541)
Tim,
If you can hook up, in cool weather you should be below 6.5 easily. I recommend switching to an R compound tire. tim |
Originally Posted by x50plt
(Post 2131127)
I am doing a simular set up staying all wheel and just ordered an lsd hope that helps.
tim |
Originally Posted by ReeknHavic
(Post 2130701)
tim |
Originally Posted by MARKSKI
(Post 2130651)
When the $$$ begins, never stops, it is like addiction. Worse than heroin, you want more and more. Let us know when you hook good and give us good numbers, do not be dissapointed buddy, better times is around the corner.
Originally Posted by art4iza
(Post 2131273)
tim |
| All times are GMT -6. The time now is 10:10 AM. |
