First it's a ABS/PSM warning, then replace harness, now it's the CEL! WTF!!
Old Nov 18, 2008 | 08:39 AM
Turbo Fanatic's Avatar
It can happen either way.
Originally Posted by MikeR
Before replacing the harness, did you get the CEL with the ABS/PSM lights? From what I read from other past threads, it seems that the MAF problem has ABS/PSM and CEL lights. From the few of us that replied to your last thread, we didn't get the CEL, just ABS/PSM, which we had actual ABS/PSM issue, not the MAF. Good luck with this, I know it sucks.
For those of you that had MAF issues, and you got the ABS/PSM lights,
Did the ABS Failure and PSM Failure, take car into nearest dealer immediately messages appear on display?
Or did just the little round ABS and PSM light illuminate?
Old Nov 18, 2008 | 08:44 AM
LUISGT3's Avatar
I have an extra Alum Vflow upgrade if you don't have it and want it.
Look into getting the Hitachi Maf (with the proper tune) and your issues will go away.
Old Nov 18, 2008 | 09:42 AM
MikeR's Avatar
MikeR is infamous around these parts
Thanks. In my case, I never got a CEL. It was only the failure messages.
Old Nov 18, 2008 | 12:38 PM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
Hitachi MAF FTW!
I have a Vflow upgrade (without a waffle) that I'll send to ya if you'd like. I had Evo send it to me and then I decided to just do the MAF upgrade instead...
Old Nov 18, 2008 | 12:43 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Luis I will PM you. Thanks.
Old Nov 18, 2008 | 01:07 PM
flash68's Avatar
Maybe these codes/issues truly have been unrelated. I am hoping it was first the harness and then now the MAF and by replacing both those and adding this v-flow upgrade thing I can be okay again... for awhile.
I don't want to upgrade the MAF yet because I do not know which turbo upgrade kit I will be going with yet in the next year - Proto, EVOMS, etc....
thanks everyone for the help.
Old Nov 18, 2008 | 07:56 PM
flash68's Avatar
I bought a cheap scan tool and confirmed the MAF destruction with P0102 code. And the ABS/PSM and CEL are all on all the time now, whereas before the ABS/PSM were intermittent. I ordered a MAF from SpeedTech and will install that when it gets here and hopefully solve the issue for now. Gotta see if I have the upgraded V-flow or not now and go from there....
Thanks for the offers and help guys. Appreciate it!
st4rk
Mid-Atlantic
Nov 28, 2015 10:35 AM
bmwtmx
Aug 26, 2015 07:26 AM
oddjob142
Aug 24, 2015 05:49 PM
TrackOne
Aug 20, 2015 12:56 PM
