-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   DV's failed again and again (https://www.6speedonline.com/forums/996-turbo-gt2/155862-dvs-failed-again-again.html)
drlaw99 Dec 23, 2008 09:38 PM
OK, I know about the 'honking noise' and I had my DV's swaped out under warrenty in October. Everything was great for about 3 weeks, and the 'honking noise' is back! Any thoughts? Will the dealer just continue to replace them ever 30-45 days, or has anyone had any luck getting them replaced under warrenty with something that works. Should I just bite the bullet and install them myself?
markski@markskituning Dec 23, 2008 09:44 PM
take it back.... its not ur fault... it should work as OEm....
maybe its something else...
ExclusiveTT Dec 23, 2008 10:21 PM
i know this sounds like a stupid question, but is the car stock?
sharkster Dec 24, 2008 01:03 AM
I know the bosch ones no matter how many different times you install them can fail quite quickly _if_ the car has been modified with an ECU program and is running more boost. Even in stock form they can fail quite quickly....
drlaw99 Dec 24, 2008 01:31 AM
Other than a Fab cold air, it is currently bone stock.
oak Dec 24, 2008 04:42 AM
do your self a favor and get a pair of bailey dv's. it's a job you want to do once. mike @ AWE board sponser has them in stock. clicky the linky to the right...
Brian@Performance Outfitters Dec 24, 2008 08:14 AM
I have Hyperboost Compact Stealths INSTOCK ready to ship...
Regularly 159 each...
$290-300 Shipped.pending on where you are.
Brian
http://www.stratmosphere.com/hbdvcsmooth_blk_146.jpg
ard Dec 24, 2008 09:59 AM
I'd fix the underlying problem first before throwing new parts into the mix. What are the peak boosts you are seeing when you drive??????
onelove Dec 24, 2008 10:52 AM
DV's are definitely something you should replace off the bat stock, if you plan on upgrading the car it's even more important.
Standard Issue 996TT Billet Diverter Valve (pair)
$219.00 for the pair, enter december in the checkout and they're $209.00. Produced by a proven manufacture exclusively for us.
drlaw99 Dec 25, 2008 01:52 AM
Thanks guys.
ExclusiveTT Dec 26, 2008 02:01 AM
dumb question: what are the effects of "bad" stock DVs?
MBailey Dec 26, 2008 06:04 AM
Lost boost or worse piece of bad DV ingested into turbo...
Ray C. Dec 26, 2008 08:21 AM
I am very satisfied with the I-Forge DVs from Champion motorsports.
Szpet Dec 26, 2008 08:32 AM
I`m running the AgencyPower DVs from Vivid and they work perfect. I think all of the aftermarket DVs from well known sponsors will work great.
