Best ball bearing turbines for 996 TT/GT2.............
Guys,
I need your opinion according performance ball bearing turbines with kkk exhaust housing.
I would use them in 997 tt next project, there are nearly bolt on. Need about 1300 kilograms each with fast spooling.
Thanks for help.
Karol
Thanks for help.
Karol
I may be wrong, but I don't think there are any ball bearing turbos with KKK exhaust flanges. The Tial hybrids (k16/GT28 or k24/GT30) don't use ball bearings. Same goes for the Mistu hybrids (k16/16g, k24/18g, k24/20g).
We have a propriotary garrett tubro that does not need water lines and outflows the gt3076r... Ill have some 60 and 130s next week... watch out guys...
markski
2001 996TT 3.6L and stock ECU
Contact Greg at Tial. He has not publicly released the new housings yet. I have seen them prior to install and they are spectacular! They look like GT25 exhaust housings with standard K16/K24 bolt patterns. There are 2 different AR's available. The larger one accepts GT30's and maybe more. The placement of the wastage is ideal because it blows in the same direction as the turbine. Tial has also isolated the turbine exhaust with a cone/tube to help flow prior to it converging with the wastegate.
Installed in a 993tt they have been VERY impressive! Much more so than the past GT conversion into a KKK housing. That housing is flawed because the wastegate blows accross the face of the turbine wheel reducing overall flow.
Greg can tell you more about his offerings.
