can't remove hood crest - help
I bought a silver hood crest to replace the stock one ... but I can't see how to remove the stock one on an '03 Turbo ... the screw is far recessed into the cut out of the metal, and there is no thread to insert the screwdriver head into anyway.
Has anyone removed the hood crest and if so could you pls instruct me as to what I am doing wrong? THANK YOU :) |
DO NOT USE a screw driver!!
Try a 1/4" drive 8mm deep socket. Loosen both nuts and the emblem will pull up from the hood. Becareful not to lose the nuts behind the beam support.
I was about to take a pic of the tool...
but Oak saves the day again! :) |
alamein - out of curiosity where did you get the silver emblem?? Someone told me FVD is having a special and is selling them for $50 a pop but I couldnt find anything ontheir site and I e-mailed them....I dont think they care anyway cause i only requestd a catalogue like 3 times but never got one!! Talk about customer service!!
Originally posted by msindi alamein - out of curiosity where did you get the silver emblem?? Someone told me FVD is having a special and is selling them for $50 a pop but I couldnt find anything ontheir site and I e-mailed them....I dont think they care anyway cause i only requestd a catalogue like 3 times but never got one!! Talk about customer service!! Pelican Parts Crest |
What do you mean by "Booth Crest"?
Originally posted by msindi What do you mean by "Booth Crest"? The box had a label on it that said "Boothe Crest" Ralph makes quality products... |
thats what i thought but i guess you spelled it without the e at the end originally...i will call ralph tmorrow as i wanna get some chrom lug bolts and no turn centers ;)
Here is a picture of the no turn center caps on Ralph's car with his nickel plated bolts...
http://a6.cpimg.com/image/DC/BC/2241...-02000180-.jpg |
I have not seen a silver crest in person why do you guys like it so much? Just curious?
:confused: |
especially on the silver cars, the silver emblem just looks so much cleaner. It's kind of like changing the turn signals to clear.
btw - cec can get it for you too. |
EM 996 GTS, OAK -- thanks a lot for your help ... it was easy once I used the right tool. Looks good too.
msindi - I bought it from one of the vendors at the AutoFest (left side of north exhibit hall - can't remember the name) ... however I don't think it was an original part as it doesn't have the markings on the back the original one has (Made in Germany, serial #, maker name (Deumer), etc. -- I only realized this once I pulled off the original) ... it looks exactly the same except for 1 minor difference which is undectable imo unless you put the original next to it (not as smooth on the red/black striped area as the original). I would recommend finding a place that uses an original part refinished if there is such a place. |
Silver Hood Badges
Originally posted by alamein EM 996 GTS, OAK -- thanks a lot for your help ... it was easy once I used the right tool. Looks good too. msindi - I bought it from one of the vendors at the AutoFest (left side of north exhibit hall - can't remember the name) ... however I don't think it was an original part as it doesn't have the markings on the back the original one has (Made in Germany, serial #, maker name (Deumer), etc. -- I only realized this once I pulled off the original) ... it looks exactly the same except for 1 minor difference which is undectable imo unless you put the original next to it (not as smooth on the red/black striped area as the original). I would recommend finding a place that uses an original part refinished if there is such a place. |
Ralph - I did not buy a hood crest??!!
I was gonna call you to get one and a set of lug bolts and no turn centers for my HREs... |
| All times are GMT -6. The time now is 10:44 PM. |
