Ultimate MotorWerks Stock K16 does 480 RWHP
#46
My car is right around 3200(after putting the front rebar on) and the run was at 1.0 bar or just under 2000hPa.
STD pressure is 29.92 and Standard temp is 72F. I would then expect STD to correct to this number not 60F. The pressure was higher that standard, again taking away from the numbers slightly. The temp correction def helped out.
I am familiar with the Colossal Goat F$%$ that can go down with discussing dyno numbers.
Divexxtreme, did you happen to Dynojet your stock Z06 that ran a 7.8X? Since our times are so close, I just wanted to interpolate this pull to whatever RWHP your 'vette was putting down.
In no way do I think that putting up this dyno graph to be an indication that my car is as fast as a 24/18G, or 16G's or GT28's or Marty's car or Marek's. I've listed my weight, 3200, my boost 1.0 Bar, my 60-130 times 7.98 and the best of both worlds of my 1/4 times, 11.64 and 125.X.
Just posting these numbers for fun. I know I still have a little ***** car with sissy K16's. Hahaha
#49
Guys, you can not compair mustang dyno numbers to dynojet numbers. It's apples to watermellons! lol
Most Mustang Dynos read around 50 rwhp less than dynojets due to them being load bearing dynos. Also, awd cars lose a little more power through the front dif. Add that all up and you will see why cars can make such different numbers.
#54
Plan on doing the TX2K9 event tomorrow for drag racing and then 60-130 on Sunday.. I hear Tony is going to buy me some axles if things go south.
Sorry for the highjack Ryan LOL!
#55
^^^Does he know this?
Wish I could be there. I finally got a respectable time yesterday though...
you should be heading DEEP in to 5's...
#56
That is quite an achievement on K16's!
#57
**** yo couch, $%$#@, **** yo couch. Darkness!!! Darkness' couch. Buy another one you rich motha licka
#59
Wow that's insane numbers. I didn't even think that was possible on k16s..
What octane are you tuned for?
you don't even have simple bolt ons like exhaust or an intake??
I'm hoping I can dyno even close to that.
#60
Had I dyno'd my stock Z06 the same day as you, on the same dyno, in the same environmental conditions (mid 70's)...I bet we would have been within 10-15 rwhp of one another.
Our weight and performance numbers are almost indentical as well. My car weighs around 3,200 lbs with the 2LZ package (without me in it), I trapped 127 in the 1/4, and went 7.86 60-130.
I personally believe that your car is making that much power...or damn close to it.
