-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   Something strang I've noticed today (https://www.6speedonline.com/forums/996-turbo-gt2/171074-something-strang-ive-noticed-today.html)
adam699 May 5, 2009 02:31 PM
Well, I've attempted to calibrate my fuel guage in a gheto way. I took my car to the gas station when on empty, disconnected the battery, and proceeded to fill up the car. Well, the car wouldn't let me fill it up and would just spit fuel back at me!!! WTF....at first I freaked out, but than reconnected the battery and all was nice and dandy. Well, the bad part is that since I wan't able to fill it up with the battery disconnected, my guage now shows 3/4 full.
So, what causes the car to spit fuel when the battery is disconnected?
ixotuckeroxi May 5, 2009 02:55 PM
the eletronic flapper is shut (when disconnected). same problem they have when the circuit shorts, flapper stays closed not allowing any gasoline in.
justinn May 5, 2009 02:58 PM
check the fuses under the dash...
Justin
Chuck Jones May 5, 2009 03:47 PM
There is a fuse under the dash that's dedicated to the gas fill spout....when that fuse blows, you can't put gas in the car....do a search on this subject....there's been a number of writeups on it.
adam699 May 5, 2009 07:06 PM
Where is the flapper located?
Guys, checking my fuses will do nothing as I was trying this with the battery disconnected.;)
raineycd May 5, 2009 07:28 PM
Hmmm. Putting gas in the car and sparking the battery, sounds exciting!
Danyol May 5, 2009 08:02 PM
Silly question - with all the issues with the flap, how do you know the tank is full?
ixotuckeroxi May 5, 2009 09:10 PM
from what ive read, its between the fender filler and the actual gas tank. theres plenty of threads about this concerning filling conditions when the fuse is blown and gas must be trickled in.
justinn May 5, 2009 10:01 PM
Then there's no power to the fuse, the flap, or anything else. Connect the battery and fill it up.
Justin
adam699 May 5, 2009 10:23 PM
Well, I reconnected the battery and filled her up with 14gallons of fuel. How much does our gas tank fit???
BTW:) Everyone seems to misunderstand me. My flap is working fine. There has been no issues with my flap up untill I disconnected the battery. Once I reconnected it everything was dandy.
jimmer23 May 5, 2009 11:17 PM
Ummm, connecting/disconnecting a battery at a gas station pump has got to be the dumbest thing I've ever heard. [Picture the scene in Zoolander with the gasoline fight.]
adam699 May 6, 2009 02:26 AM
So is wearing wool pants that could rack up static electricity.
Anyway, I did that right after I put out my Capri and took a sip of "Orange Mocha Frappucino".
jimmer23 May 6, 2009 09:15 AM
Hahahahaaha :D
Danyol May 9, 2009 03:55 PM
Looking in the manual I see "refill volume 63 L". sounds like a lot? Converting to US gal liquid I see 16.6 (Imp 13.65) - I've never gotten that much in there...
Anyone know the answer to this?
Chuck Jones May 9, 2009 04:12 PM
I just went thru a formula for upping octane in a tank of gas on a 996TT and the specs I got was that the gas tank holds 64 litres...which converts to 16.9 gallons. One time, I got 15.9 gallons in there and thought that I was running on fumes....according to the specs, I still had one gallon left...but I wasnt' about to test the theory.
