Softronic Question..
Old Jun 1, 2009 | 08:58 PM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
Ok, so I've uploaded the new tune on my car from Softronic and made a few runs on the highway. I also made a few just fefore the install for comparison.
Stock max Bar in 4th = .8 bar
After Softronic Tuned install = .8 Bar
Butt dyno says it feels the same.
Any ideas? Is this a program that learns and builds up after a few days, or should the change be instant?
Help!
Old Jun 1, 2009 | 09:02 PM
ezeks's Avatar
ezeks is infamous around these parts
My tune isn't softronic, however once it was loaded it was an immediate difference (1.1-1.2 bar) and the butt dyno definitely told me a tune had taken place. My guess is the flash didn't load, however not being familiar with the softronic loading procedure I can't offer you any advice except to ping Dan @ vivid. They may still be online for assistance...
Old Jun 1, 2009 | 09:08 PM
Prche951's Avatar
butt dyno means not much. Also, what conditions did you do your stocker run? was it cold weather? vs warmer weather? having said that, you should be seeing a bit more boost. do you have stock exhaust?
also did you get a hold of softronic or whomever their rep is that sold it to you?
Old Jun 1, 2009 | 09:16 PM
The conditions were near identical. I did the stock run about 20 minutes before the tuned run.
65 degrees - clear
Stock exhaust, Agency Power intake.
Will try Dan.
Old Jun 1, 2009 | 09:27 PM
OK,
I've written to Dan at Vivid and back to the Softronic guy that sent me the tuned file.
We'll see what they have to say about this.
Old Jun 1, 2009 | 09:32 PM
Prche951's Avatar
Originally Posted by ColoradoSilver
OK,
cool. it should get sorted out. You definitely need an aftermarket exhaust. It really brings these motors alive with the tune.
Old Jun 1, 2009 | 09:46 PM
ezeks's Avatar
+1 I followed the advice here and did exhaust before the tune as well
Old Jun 1, 2009 | 10:00 PM
wross996TT's Avatar
to add my .02...the tune should be instant...sure there is some ECU learning, but you should see boost 1.1 at least...hope you get it sorted.
Old Jun 1, 2009 | 10:36 PM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
i've a softronic tune and i see 1.2 bar ... may be somehow is wrong during the upload?
Old Jun 1, 2009 | 10:41 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
Ive felt it on a regular 997... on a Turbo it should be a big change...
Old Jun 2, 2009 | 12:29 AM
GT3 Chuck's Avatar
Administrator
why don't you get it from the horses mouth...in this case Scott Slauson at Softronic:
https://www.6speedonline.com/forums/...=newpm&u=23983
Old Jun 2, 2009 | 05:49 AM
Prche951's Avatar
sounds to me like the factory tune is still in the dme. I can see this being the most likely cause of the problem.
Old Jun 2, 2009 | 06:38 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
PM me if you'd like. I happen to be an expert at loading a Softronic tune.
Old Jun 2, 2009 | 06:39 AM
Imolas54's Avatar
Imolas54 is infamous around these parts
I would double check to make sure you didn't upload the stock file instead of the tune file or they may have named the files incorrectly.
Old Jun 2, 2009 | 07:10 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
No big deal. Looks like the file did not upload. Just call Scott and he will sort it out. No need to panic....
