Race Results: Tial GT28 Tip vs 6 Speed 18g car
Vinod- I don't think you can even begin to compare the 2 turbo's based on 1 race between 2 completely different set up cars...
Keep in mind that I have 6 speed k16/16g's runing 6.9-7.0 60-130 (SealGreay). BlackHorses k24/18g tip cars runs 6.89 60-130 @ 1.3 bar of boost.
Using your method of compare k16/16g = k24/18g...
Im sure Ill get flamed for this one, but lets be relistic for a second....I would love to see a race between Vince and BlackHorse, now that woudl be a REAL compare.
Also hoping that with your custom 1.3 bar tune and injectors and meth ...i should murder the tip GT28 car...correct??...
To all who are reading this ...this is by no means a Turbo comparision...its apples and oranges here!
I edited the message, I knew I'd get the wrong message acrossed. The original message said "I take BHT any day"... I meant between BHT and Vince.
Also Tony’s mustang dyno reads a lot lower than Dynojet. I agree the best way is to post 60-130 times, these dyno numbers are proving to have bad correlation to street runs due to other factors.
. either way slice and dice...we started at 45 and shut off at 140.I am not the one who wanted to race...
"Action" meaning doing races all the time and not on a Dyno.
!Also, I emailed you back about your injector DC. Did you that the graph I sent?
