Brembo Brake Q
Old Jun 29, 2009 | 07:44 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Brembo Brake Q
does a 15mm spacer added to the stock turbo twists let them clear the Brembo 6 piston 350mm BBK (fronts only)?
Old Jun 29, 2009 | 10:19 PM
Prche951's Avatar
D33PBLUE on here has the 350mm rotors and brembo calipers I think (or GT2's, which are the same thing) and he did not need spacers for the fronts. PM him he can probably tell you more.
Old Jun 30, 2009 | 07:13 PM
WOODTSTER's Avatar
NO,
It doesnt need to come out (the wheel), it needs a larger ID to clear the
Caliper (not the rotor). I know this.
MK
Old Jun 30, 2009 | 10:07 PM
LiNks's Avatar
I got ya... so basically if I get a Brembo BBK I need new wheels to clear them. Thanks
Old Jul 1, 2009 | 10:39 AM
vividracing's Avatar
Yeah Brembo 6piston 355mm will not clear the stock turbo twists. It is the caliper height not the offset. Customers wanting a 6piston upgrade can do the GT3 calipers with the Brembo 350mm 2pc rotors as seen here.
We also have worked with Rotora to come up with a 6piston 355mm kit that works with the stock turbo twist wheels.
Old Jul 1, 2009 | 02:57 PM
LiNks's Avatar
Rotora... hmm could you PM the price of that kit, cross drilled and slotted if possible?
Old Jul 1, 2009 | 03:15 PM
PM being sent.
Rockinc1
Sep 30, 2015 06:44 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
