RWD tiptronnic cars...Chime in!!!
Hey guys
I'm thinking to convert it to RWD..Is really worth it? Any issues so far?? quicker 60-130?? what about driveline loss %?? Thanks |
Originally Posted by Shotcaller
(Post 2454865)
Hey guys
I can't give you statistical before and after data, but I have had no problems since converting to RWD. I've put up some good times and I do not have traction issues. The weight savings is a big plus too.
Thanks Todd
(Post 2455104)
Thanks Todd
So whats the safest way to do the conversion? Do I have to purchase any type sway bars, do an alignment? What should the cost be around?
Thanks |
Originally Posted by 007-911
(Post 2455150)
Thanks There are no special parts to buy at all. As far as alignment goes, I realigned and corner balanced when I added the PSS10's, GT3 sway bars and drop links. I'm not sure if you HAVE to realigned just because of the RWD conversion. |
(Post 2455150)
Thanks There are no special parts to buy at all. As far as alignment goes, I realigned and corner balanced when I added the PSS10's, GT3 sway bars and drop links. I'm not sure if you HAVE to realigned just because of the RWD conversion. Cost just for the RWD conversion should only be related to a couple hours of labor. |
how much weight did you save? Is it easy to drift the car?
I want to say the parts weight about 75lbs or so. Haven't tried drifting yet..
Originally Posted by BlackHorseTurbo
(Post 2455293)
What about TX2K9 on the road course when you were murdering your tranny?hilarious |
Originally Posted by ttboost
(Post 2455856)
(Post 2455285)
On the other hand my M3 is the PERFECT drift car (only drifted her by accident when coming through a corner hard.....she just held the slide flawlessly until I straightened out). |
Originally Posted by Dr_jitsu
(Post 2456492)
You absoltely do NOT want to drift a 996TT/GT2....w/ the rear engine and overall physics of the car you will break axels.
On the other hand my M3 is the PERFECT drift car (only drifted her by accident when coming through a corner hard.....she just held the slide flawlessly until I straightened out). Was it still raining or did it just stop?hilarious |
