Fuel pump system exposed, a couple of pictures
Well I found a memo from Porsche to EPA because it is a fuel system problem stating that a bit over 8% of the newer 996TT's had pump failures but no release to atmosphere of fuel. The corrective action is a revised part and old parts pulled from shelf.
Huh. I wonder as this is a report on the "newer" 996TT's. I wonder what the failure rate of the old ones are given the longer exposure to ethynol.
Also, 8% were covered by warranty. I wonder if another 20-30% or more were out-of-pocket? Mine is going on it's second replacement pump on a 20k mile car and I'm a little hot about buying a $500+ pump that's known to be a problem. Hopefully the newest incarnation does the trick. Just wish Porsche would pick up the part, I'll eat the tow.
Here's a link to the memo.
http://www.regulations.gov/fdmspubli...ontentType=pdf
jjbravo, thanks for link, i guess this is why the new one doesn't look like my old one, must be the updated version and my new part number did in fact end up with 02 so it is the new piece.
This is a great thread with a lot of helpful info BUT, I need to replace just the motor with a pump that is capable of 60psi constant, has anybody replace just the pump? are all the in-tank motors, such as the Hi pressure walbros the same size or easy to adapt?
Nope. You're SOL. That's why adding a second inline pump is common. Search and you will learn.
not true at all. inline pumps are a failure waiting to happen
contact sean at silly rabbit motorsport in las vegas. he builds billet hats with a brushless pump that can handle what you need.full in tank setups with just that up to a full system with billet rails, lines filters etc. there is also an application that can run the fuel pressure thru the dme with pwm and boost requirements so no fpr is needed
it actually is a simple drop in if you use the right product.the sam product is a complete no wire cutting drop in unit. a second inline pump or boostapump won't keep the car safe if it fails and will run the car lean. its a poor bandaid and always has been.
If you do the single pump Sean's setup is pretty much PnP, dual pumps require running lines. It's possible to drop a Walbro into the stock holder but you'll need to use a hose clamp on the pump to stabilize it in the plastic holder and modify the wiring. Sean does have a brushless pump too that can be PWM.
Why 60psi constant? Most regulated setups vary the pressure. How much FLOW do you need?
P.S. Not a fan of inline pumps myself either...
I've installed a GM LS3 480hp V8 crate engine that according to the installation paperwork needs 60psi. I've removed the stock Porsche computer variable pump psi computer controller and am getting 55psi idle that will drop as low as 45psi during acceleration, I'm worried that it will run to lean with these pressures. Which Walbro pump do you recommend ?
If it's dropping at higher fuel consumption levels and your FP is static, then your pump doesn't have the FLOW to handle your HP requirements. I'm assuming this isn't a forced induction setup either.
I also prefer proper in-tank fuel pump to external if possible. I just wish it were easier modifying our fuel systems. I ended up copy'ing johnny.dangerous' setup with running a FP to the bottom of each sump in the fuel-tank. It has been working great so far. Even at a little over 1/4 tank for fuel, my fuel pressure logs haven't budged....even on the twisties. I'm not staging mine either. Dual 340lph doing work full time in my tank.
